I have a 85" CJ7, 258 ci, that has no spark from the coil. I had a comple wiring harness melt down and bought a wiring harness from Painless Wiring. I rewired the entire jeep and had it running for three weeks when out driving it quit running. I have no spark at the coil, I replaced it, the ignition module, rotor, cap, distributor pickup, solenoid, even the ignition switch. Still no spark. The coil has 12 volts on both sides of the coil when the ignition is in the run position. All conections are solid nothing is loose. Motor turns over with no problem. Anyone have a suggestion?
