    Boze's Avatar
    Boze is offline Senior Member
    Jan 2009
    San Diego, Ca
    199
    Question Will my Jeep run if I remove my emissions junk?
    In Crook County Oregon, (where my Jeep is registerd), there is no such thing as emissions controls. Therefore, I was wondering if I could lose all the lame-o smog junk on my 4.0. If I do this will my Jeep even run? Someone out there has to have tried this. Thanks guys.
    It runs in the Family.
    SteelHeadz's Avatar
    Oct 2008
    Kerrville, TX
    6,087
    Re: Will my Jeep run if I remove my emissions junk?
    Yes it will. However, the ECU might be throwing some DTC's your way.
    Boze's Avatar
    Jan 2009
    San Diego, Ca
    199
    That's a simple fix...what fuse goes to the check engine light?
    Utah_jeepster's Avatar
    Utah_jeepster is offline Moderator
    Jun 2003
    Tempe, Arizona
    3,482
    I am not sure on how many codes it requires to send a 93 ECU into whats called safe mode, but I know three non-critical ones on a 01 will put my ECU into safe mode governing the motor to only 40 MPH for 5-10 minutes at a time.
    I will ask my mechanic friend this evening
    blatant jokessubliminal sarcasmsexual innuendo
    Collin the Hen's Avatar
    Collin the Hen is offline Senior Member
    Apr 2008
    Indiana
    591
    Quote Originally Posted by Boze View Post
    Nice.
    Bounty__Hunter's Avatar
    Nov 2002
    Southern Illinois
    13,425
    What lame-o smog junk you referring to? About the only thing to remove on a '93 is the catalytic converter, and they really don't hinder performance these days unless it is going bad.
    You can remove the catalytic converter on a '93 without tripping the check engine light.
  7. #7
    Boze's Avatar
    Jan 2009
    San Diego, Ca
    199
    Really? I guess I just assumed it had a smog pump and all that...we all know what happens when you assume. So all those vacume lines and what not serve a legitimate purpose I suppose. (is supposing different than assuming?) Thanks again BountyHunter.
  8. #8
    Nov 2002
    Southern Illinois
    13,425
    No smog pump, and you need everything else to keep the ECM happy. The only thing that comes close to robbing power is the converter, and they're not bad anymore.
  1. Junk yard alternator upgrade?
    By DeadHammer in forum CJ YJ TJ and JK
    Last Post: 07-18-2009, 04:39 PM
  2. elec. fan upgrade...junk yard option...
    By fast_Z28_guy in forum CJ YJ TJ and JK
    Last Post: 02-19-2008, 02:26 AM
  3. Junk Yard Turbo?
    By CherokeeGuy42 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 01-08-2006, 04:04 AM
  4. TOO MUCH JUNK
    By jeepin916 in forum Items for Sale, Trade, or Give Away
    Last Post: 03-27-2005, 07:11 AM
  5. Don't junk your rusty old tubs and frames!
    By Joey-T in forum Items for Sale, Trade, or Give Away
    Last Post: 10-06-2004, 06:38 AM
