    BlackStick's Avatar
    BlackStick is offline Junior Member
    Jul 2008
    Saint Paul, MN
    20
    Question How much of a lift will I need?
    BACKGROUND: I am thinking about buying a 1976 CJ7 because I think it is the best looking jeep around. Plus, they can be turned into some pretty hard core wheelers. This one seems to be in pretty good condition with a rebuilt AMC 304 (16,000 miles) and a lot of other fairly new, but not upgrade parts. The guy wants $6,000 for it I'm offering $5,200, but he wants to wait a week and see if he can get more for it.
    QUESTION: The suspension is currently stock, and I want to slap some 36X15.5R20LT Mickey Thompson Baja ATZ Radial SLT tires on it. They look great and will be the best tire for my applications (Heavy daily driving and mild to moderate trail riding and mudding on the weekends). How much of a lift will I need at a minimum? Who makes the best lift (price does not matter)? I want to be able to get decent articulation, but feel comfortable making turns on the streets. I rolled my last jeep over because I did a four wheel drift right off a freeway entrance ramp (Pictures are posted in the reader rides YJ section). I do not plan to abuse this classic like my junky YJ, but I'd like it to perform reasonably well on the street. In addition to the suspension lift, I am planning to install some aftermarket shocks. I thought that the Bilstein 9100 series would be great, but if you guys think something else would work better, I'm open to hearing it. I look forward to hearing your recommendations.
    "Never trust a man with clean shoes."
    -Mike Rowe (Dirty Jobs)
    BlackStick's Avatar
    Jul 2008
    Saint Paul, MN
    20
    Exclamation Re: How much of a lift will I need?
    I thought that it might be helpful to provide the link to the page about that CJ7 I am looking to buy. Take a look at it.
    Metallic Brown 1976 Jeep CJ7 (Car/Truck) located in the Minneapolis - St. Paul area.
    SteelHeadz's Avatar
    Oct 2008
    Kerrville, TX
    6,087
    Thats a nice looking Jeep. I am by no means an expert on this but i'll give it a shot . No more than 1 inch of body lift and a 3.5 inch suspension lift should get you by with the 36" tires. but if your going to do some hardcore wheeling with it, that might not be enough due to rubbing. Your also going to need to get a set of offset wheels and possibly wheel spacers to give you a wider stance and clearance for the front tires from the leaf springs. Quick disco's are also a good add on for articulation. Bilstein, Edelbrock and Old man Emu are good shocks but pricey. Another thing to consider is a SOA for the amount of clearance from the big tires.
    BlackStick's Avatar
    Jul 2008
    Saint Paul, MN
    20
    Thumbs up Re: How much of a lift will I need?
    Thanks, I will probably go with something around 5" total lift. I've never used body lifts before, so it will be a new adventure.
    Rubiconrich's Avatar
    Rubiconrich is offline Senior Member
    Apr 2009
    MA
    366
    I have a 86 CJ7 (now in pieces) But you will need a 4" lift and a 2" body to run 36's or cut the steelmetal or flatfenders. Do not pay to much you can
    get a 97 TJ for $5,200. or a YJ.Unless it has a T-18 4 speed.
    check to see what gears before you buy it.
    Rubicon Rich PatriotJeepers, Inc
    05 Rubicon
    86 CJ7 ,258,T18,Scout Dana 300,Dana 44's,Lockers,Twin stick,OBA,8274 Warn winch.
    51 M100
    BlackStick's Avatar
    Jul 2008
    Saint Paul, MN
    20
    Question Re: How much of a lift will I need?
    I'm fairly new to jeeps and working on cars in general. I've changed the oil a few times and can do the basic maintenance. I know where most of the components are and what they do, but I have never actually worked on them, however, I would like to start working on my own vehicle more extensively just because I want to. So, I need to know how to check the gears. Please explain. I am planning to use the Gen Right cut away fenders to give me increased clearance and make the jeep look more hard core.
    Also, I would like to know if there is a way to lift the jeep without using leaf springs and if so, what is it. I think that leaf springs are old tech and that in 2009, I should be able to put better gear on my rig. What do you recommend?
  7. #7
    jps4jeep's Avatar
    jps4jeep is offline Moderator
    Dec 2002
    Boston
    6,657
    with some rear fender trimming, you can fit a 36" tall tire with a 4" lift. anything over that is pure excess and will add to you being top heavy.
    It used to be a jeep Thing,
    But all that stuff broke
    -Johnny-
  8. #8
    BlackStick's Avatar
    Jul 2008
    Saint Paul, MN
    20
    Do you really think I can get maximum articulation of my suspension with only a four in lift? I don't want the tires rubbing. ???
  1. Alternate Drive shafts for CJ with lift(2.5 lift)????????
    By jhiggins in forum CJ YJ TJ and JK
    Last Post: 12-03-2011, 04:19 AM
  2. 91YJ 6 in rockcrawler lift or 2 in spring lift and SOA
    By Platsmith in forum CJ YJ TJ and JK
    Last Post: 10-23-2005, 11:49 AM
  3. Lift Shackles & 2" susp. lift
    By hi_c in forum CJ YJ TJ and JK
  4. Replies: 4
  5. coil spacer lift vs. body lift?
    By PASmokeater in forum CJ YJ TJ and JK
Tags for this Thread
