beavermatic
My buddy just bought a nice low mile 01 TJ, and upon inspection after hearing some noise, he notice the fan shroud was busted, and upon further inspection, notice that the motor mounts didnt seem right, and had a "wedge" piece of diamond steel between the OEM bracket and the 3 OEM mount holes on the engine.
Come to find out, someone had busted all of the OEM mount holes from the cast iron, and created a plate with drilled holes to reach to the "new" mount holes, which they screw onto the OEM bracket.
I attached a image of the mount holes, and what they should look like, but all 3 of those OEM holes are unusable/broken off on his engine...
there is a official bracket he can use that will allow him to use the "new holes" as listed in the picture, but it uses the OEM holes as well... the M.O.R.E. bomb proof bracket.
He doesnt think he can weld or reform any of the damage OEM holes as its cast iron...
is there anything he can do to securely mount his engine, or did he just waste $10,000 on what seems to be a otherwise outstanding looking TJ?
any suggestions would be appreciate
