cj5 brake lines
If it's leaking , punctured or kinked , replace it.
If your unsure of the lenght you need on your brake hoses, lift one corner of your axle and see where it bottoms out. Do this carefully while watching the existing hose you have if it's going on a full stretch. If it does, disconnect the caliper from the knuckle and measure the full lenght you need..If it's not much of a stretch, just install a limiting strap..
Well, not 100% understanding from your post...I'll assume you're looking for cheap extended brake lines. You can get standard fitting brake lines in various lengths at Napa. Stainless lines? Please. Bragging rights yeah. Will they look look trick next to your blue neons? I guess. Will you be able to feel it in the peddle or the braking of your Jeep? Hell no. Don't waste your money!!!
