Replacement track bar
zafirex
Any recommendations on a replacement front adjustable track bar or kit?
Have a 98 TJ with 4in Superlift suspension+1 in body lift installed by previous owner. And a nasty death wobble that just sheared the track bar in two.
And yeah, I know I should have worked on fixing DW before now.:redface: I did fix some alignment and balance problems, plus a worn out wheel bearing which had improved the DW before this happened, though.
I don't know if you've located a track bar or not but I've got an adjustable track bar I was going to put on my 91 Cherokee should work on your TJ. It's a rough country Bar if you are interested.
Thanks, but I just put on a JKS trackbar last weekend.
Noticed the old hole on the axle bracket had been worn to about twice its size, which probable created my death wobble. Seems to be gone now!
