Tyre & Rims for a 06 TJ
avan
Greetings all.
May be an old question but my internet is so slow at the mo that instead of looking at old posts I just ask again so please bear with me.
The ideal wheel / tyre combination for a '06 TJ is ? Open to suggestions that will increase lateral stability.....The Jeep in question has a 2" lift but still has its original rims which visually makes it look top heavy.
Thanks in advanced
if you can get them, anything up to 34" tall, 10.5" wide.
like BFG mt 33x10.5 if you can get them, Interco Special Service tires 34x9.5 etc.. once you go to a wider tire with only a stock rim, you will contact your LCA.
Hi Andre,
Check the rims / tyres on my olf TJ,
That had a 2" lift & 1" body lift.
It would not roll... not matter how hard i threw it on the slopes with lp tyres it was stable,
The RIMS not sure of the brand - have a major off set - JC also has the same rims.
This realy would assist with the stability...
God I miss the Jeeping sand trips!
Cheers from Beijing
Mark
;);)8)
