It's fairly easy to change, butyou will need a puller to take out the
crankshaft vibration damper.
Basically, remove the fan shroud and fan (if still using a mechanical fan), remove serpentine belt, remove crankshaft vibration damper, remove timing case cover and line up the marks, remove the oil pan (only if you need to replace the tensioner, which I recommend you do), and remove the camshaft retaining bolt and remove the sprockets and chain as an assembly.
To install, unlock the tension lever, pull the tensioner block toward the tensioner lever to compress the spring, then hold the block and turn the tensioner lever to the lock position, then with the key in the crankshaft keyway, install the crankshaft/camshaft sprockets and timing chain (make sure the dots are aligned), Install the camshaft sprocket retaining bolt (80 ft.Lbs), and then reinstal the slinger, timing chain cover, crankshaft vibration damper, serpentine belt and fan and shroud.
Make sure you also replace the tensioner, otherwise the noise will continue...
