    grooveman's Avatar
    grooveman is offline Member
    Jan 1970
    Montana USA
    46
    Cylinder Misfire?
    Fired up the Jeep this morning and it sounded like it was running on 5 cylinders. Pulled codes P0306 (Cylinder 6 misfire detected) and P0155 (O2 sensor heater malfunction (Bank2 Sensor1). I live in a cold climate and let the gas get low. Added some gas line antifreeze and let it run a while but its still running rough. I plan to start tearing into it when it warms up enough, just wanted to get ideas on what I should check first. Its a 2003 TJ, 4.0L.
    Thanks!
    Saddle Tramp's Avatar
    Saddle Tramp is offline Senior Member
    Apr 2009
    Vancouver USA
    612
    Re: Cylinder Misfire?
    Shot in the dark here- Are 03s coil over plug? If so I would start there.
    SteelHeadz's Avatar
    Oct 2008
    Kerrville, TX
    6,087
    Yes Kriss, it's a Coil rail system..
    Grooveman, i would check the wiring at the end of the coil rail at the connector and where it routes across the rear of the cylinder head. Sometimes the wiring will chaffe on the engine block and create a short or a misfire in this case. The P0155 indicates a bad sensor all in all if the connector is good. Bank 2 meaning , the rear exaust pipe from the manifold and the top sensor which is sensor 1(Upstream O2 sensor).
    grooveman's Avatar
    Jan 1970
    Montana USA
    46
    Ok, as soon as it warms up enough I'll check that.
    BTW, Kerrville close to my hometown. (Uvalde). Wish I was back down there.
    Thanks for the help
    SteelHeadz's Avatar
    Oct 2008
    Kerrville, TX
    6,087
    LOL, yep, Uvalde, great place to go for hunting wild pigs. We have them here too but it's getting harder and harder to find ranchers that will let you hunt them off their property..
  1. Can I replace a 4 cylinder engine with a 6 cylinder
    By stepheng67 in forum CJ YJ TJ and JK
    Last Post: 08-11-2017, 12:03 AM
  2. 2001 Cherokee Sport 4.0 bad misfire
    By Jeep77 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 05-08-2009, 05:52 AM
  3. 2000 xj misfire problem
    By JOHNBOY in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 04-06-2009, 11:11 PM
  4. 1998 5.2l p308 cylinder 8 misfire
    By idrthrbfishing in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 01-12-2008, 07:49 PM
  5. Engine misfire
    By bob in forum CJ YJ TJ and JK
