    Tug-n-pull's Avatar
    Tug-n-pull is offline Senior Member
    Oct 2002
    East Tennessee
    5,149
    1054006
    OK I was looking for a place to run in a new wire through the fire wall today. I found a line going through a gromet near center of the firewall. I was trying to fit a low volt small wire through along side. pulled just a bit and it gave way from under the dash some where. It turned out to be a very small vacuume line. On the motor side it seems to fit into the back of the manifold but where oh please tell me where does it go under the dash. I see no change in the driveing or running, The 4x4 light still goes on when shifted to do so. thanks tug :-? [addsig]
    Jeepr89's Avatar
    Jeepr89 is offline Senior Member
    Oct 2002
    Lincoln, NE
    392
    1054008
    It might have to do with the heater/A/C??? Or maybe for one of the guages??? Well I knew that you would pay for that working gas guage ;-) [addsig]
    idrthrbfishing's Avatar
    idrthrbfishing is offline Senior Member
    Oct 2002
    ehc nj
    113
    1054020
    start the engine and spray carb cleaner into it if the engine changes its important else put a screw in it until spring when you can look under with a good flashlight to find its mate, probably for the heat damper/defrost or the like.[addsig]
    2000 xj sport I'll be on the beach fishing.
    CARDOC123's Avatar
    CARDOC123 is offline Member
    Jan 2003
    42
    1054021
    Oh tug, so sorry!!! But like the others I think it also goes to the heater/ac door or switch. You're moving along pretty good. You'll be finished before long.[addsig]
    Tug-n-pull's Avatar
    Oct 2002
    East Tennessee
    5,149
    1054039
    All good advice and I thank you all. I think I shall just not worry and wait to see what does not work. I will run the carb spray test you spoke of and like the man said if it does not change the motor screw it! hehehehehe Tug :-D :-O :-D [addsig]
    bigTlilODD's Avatar
    bigTlilODD is offline Senior Member
    Oct 2002
    Albuquerque, NM
    641
    1054054
    It's you halogen fuel line
    Sorry, BAD Todd! [addsig]
  7. #7
    Tug-n-pull's Avatar
    Oct 2002
    East Tennessee
    5,149
    1054091
    My lights have started to dim can you tell me where to plug it back up to. :-D :-D Tug[addsig]
