    Turbogus's Avatar
    Turbogus is offline Senior Member
    Nov 2005
    Albany~town, Oregon
    1,328
    The 'Betty' page (and no, I don't mean Bettie Page)
    So, been doing several mods to 'Betty' over the last couple of years and the latest was installing an Class M clutch rod setup, as part of a compliance with that JP article regarding CJ fixes/upkeep a couple of months back.
    My question is, despite the instructions (sketchy as they were) they were clear that no parts of the OE lower rod setup are to be used in conjunction with the Class M. So they have the threaded lower clutch rod end in contact with the throwout bearing arm directly. The OE? setup used a ball end threaded sleeve, apparently to ease griding against the thowout arm. Any ideas if this is kosher?
    Quick fixes are so named for how long they stay fixed.
    If you run out of gas, no matter which way you decide to push, the closest gas station will always be uphill and in the other direction. Corollary: The likelihood of running out increases when all of the nearby gas stations are closed.
    The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep.
    We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch).
    jps4jeep's Avatar
    jps4jeep is offline Moderator
    Dec 2002
    Boston
    6,657
    Re: The 'Betty' page (and no, I don't mean Bettie Page)
    well, thats better.
    As for your clutch, If I am understanding exactly what you are saying, I see no problem assuming you have full range of motion. if you can, try to incorporate a AG heim joint to join the two.. Pics certainly would help just know exactly what you are talking about.
    It used to be a jeep Thing,
    But all that stuff broke
    -Johnny-
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,328
    The photos show the OE rod adjuster on the left and the M Class on the right. The shorter rod shown has no 'clutch rod adjuster' attached, further, the instructions specify that no OE hardware is to be used.
    piratessoul's Avatar
    piratessoul is offline Member
    Oct 2009
    South Alabama
    43
    Mee-freakin'-yow!!!!!!!!!!!
    Just wanna' get a little dirty ; - )~
    jps4jeep's Avatar
    Dec 2002
    Boston
    6,657
    the adjustment would be in the heims.
    -Johnny-
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,328
    Right jps, I'm clear on that but notice the ball end of the adjuster on the OE adjuster, then, the threaded rod end of the class M, either of which would be in the detent of the clutch fork. My concern~wouldn't the threaded rod abrade the detent to the point of break-through eventually?
  7. #7
    SteelHeadz's Avatar
    Oct 2008
    Kerrville, TX
    6,087
    The thoery of the detent ball eventually wearing through the clutch sounds kosher however, I've haven't seen it happen. I keep mine greased every oil change and haven't had problems with it.
  8. #8
    jps4jeep's Avatar
    Dec 2002
    Boston
    6,657
    I wouldn't worry about it. if it truely is a concern.. and I am just thinking out loud here... where the ball sits in the clutch fork, I would drill a hole that is about 1/8-3/16" larger than the threaded rod (basically removing the "female" portion where the "ball" sits in. I would go to the auto parts store and pick up some basic rubber sway bar end link bushings bushings, one on each side of the hole you drilled and then stick the threaded rod through and secure it with a Nylon locking nut. shouldn't wear it out, still have some of the flexability
    -Johnny-
  9. #9
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,328
    Thank you jps, also I was thinking of a crown nut serving the same purpose
  10. #10
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,328
    [QUOTE=SteelHeadz;232097]The theory of the detent ball eventually wearing through the clutch sounds kosher[QUOTE]
    The adjuster on the OE unit showed no signs of wear either Steel, but this M class rod has no ball end~just the threaded rod itself, hence my concern with it abrading the clutch fork
  11. #11
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,328
    Contacted the manufacturer and their response was "There are no additional pieces to the kit. The threaded rod insert is designed to recess against the clutch fork. We have been selling them for many years this way and have never heard of one excessively wearing the clutch fork. However, if you would like to put an acorn nut on the end of yours that would be fine and it would not negatively effect the linkage kit. The threads on that rod are 3/8" - 24 (fine thread)."
    So I think I'm going this was to err on the side of caution.
  1. New main page - what do you think?
    By TerryMason in forum Forum related
    Last Post: 09-18-2009, 08:03 PM
  2. Our New Clearance Page!!!
    By CyberJeepEric in forum 4x4 Vendors
    Last Post: 09-30-2008, 02:58 PM
  3. Got a web page
    By Roundeye in forum General Chat
    Last Post: 01-19-2004, 09:12 PM
  4. Page one ownage!!!
    By BobJ in forum General Chat
  5. web page
    By Jeep#3 in forum General Chat
