Re: Headlight issue
cali_92
Re: Headlight issue
only my brights work?
-checked connections=good
-checked bulbs=good
-checked fuse=good
when i turn on my lights i get not low-beams
??? so.. any suggestions?
Re: Headlight issue
Trace the circuit of the low beam in the switch and jump it. If the low beam works, the switch is bad.
Re: Headlight issue
Sometimes the female blade socket within the plug get pushed backward out of the receptacle housing, thus breaking the connection. Also check for corrosion within the plug.
Re: Headlight issue
That happened to me; if it is the case, head over to Advanced Autoparts, and buy new sockets (they were like $5) and put new sockets in there...
Re: Headlight issue
Speaking of headlights... I got these GLASS lensed headlights for my other truck 'BBB' and wow what an improvement over those plastic composites. I may have to add washers for the hold downs but that's no mean feat.
