strykersdaddy
ok i was out wheelin and tore the mounts for the front shackels off. ok i got a reversal kit welded it got that done. i put a high steer kit on witch i had to change the brakes on the passenger side to a 91 for the high steer kit to work. ok . so now my brake is locked up on that side. could it be because i didnt change the pads on the other side or is my new caliper shot? next question i heard a friend getting axles out of cherikets(sorry bad speller)does anyone know what years i can use? and i need to raise the rearend now cause of the reversal kit, sould i use a shackel or add-a-leaf? thanks freinds i need some help to gett back out there
