    rhess0150's Avatar
    rhess0150 is offline Junior Member
    Nov 2009
    3
    2006 Wrangler 2.4 crankshaft postion sensor
    Can anyone tell me where on a 2.4 liter 2006 Jeep Wrangler the crankshaft position sensor is located? The dealer told me mine was bad but did not have one in stock. I figure I can replace it myself and see if my problem goes away.
    Thanks,
    Aug 2010
    Mesa Arizona
    64
    Re: 2006 Wrangler 2.4 crankshaft postion sensor
    Did you ever get a reply? If not let me know and I will pm the loaction of your crank sensor when i get to my ALLDATA
    SteelHeadz's Avatar
    Oct 2008
    Kerrville, TX
    6,087
    I missed this one. It's on the right front side of the cylinder block.
    crdub09's Avatar
    crdub09 is offline Junior Member
    Nov 2010
    2
    I have been searching for my crankshaft sensor in my 2003 4 banger TJ and I cant find it anywhere!! I have followed just about every single cable bundle for over and hour, checking the front, back and sides. I cant find the damn thing anywhere. I have the replacement part sitting in my lap right now and its homeless. Someone help me out here!
    SteelHeadz's Avatar
    Oct 2008
    Kerrville, TX
    6,087
    Quote Originally Posted by crdub09 View Post
    It's the same as the one on the diagram for the 06..
    crdub09's Avatar
    Nov 2010
    2
    Quote Originally Posted by SteelHeadz View Post
    I subscribed to alldata after I made that post and figured it out. That diagram that was posted has no reference points, and isnt really relevant other than showing where it is in relation to the motor mount, which I didnt know was in fact the motor mount.
    The damn sensor is located behind the oil filter and it didnt even fix the problem when I replaced it. Camshaft sensor next...
  1. 2006 Jeep Wrangler Misfiring
    By JesusRocksMyWorld23 in forum CJ YJ TJ and JK
    Last Post: 06-05-2009, 12:36 AM
  2. 2006 Jeep Wrangler Investigation
    By southtj in forum CJ YJ TJ and JK
    Last Post: 04-26-2006, 10:10 AM
  3. 2006 or 07 Redesigned Wrangler
    By southtj in forum General Chat
    Last Post: 02-23-2005, 09:08 AM
  4. the new grand... the 2006 wrangler?
    By jeepsnsoccer in forum General Chat
    Last Post: 07-14-2004, 01:39 PM
  5. crankshaft sensor
    By balloo93 in forum Cherokee, Commander, Wagoneer and Liberty
