peterblesi
I have a 1979 CJ7 with a 304 5.0L. 3 years ago the engine was fogged and the jeep stored. It's now to the point where I can start it.
Yesterday, I spent about 40 minutes trying to keep it running (another problem). Started it many time (about 25). In between tries (with the keys out of the ignition), the engine started turning over on its own very slow (as if the battery were dead).
I disconnected the battery to stop it from starting. I reconnected the battery and it did it again. When I tried to start with the keys, it would not turn over. Only clicking as if the battery were dead. Volt meter tells me it's at 12v.
When i disconnected the battery for the final time, there was a large spark between the battery and cable. This tells me there is a large drain on the battery (I assume somewhere in the ignition / starter system).
Any ideas what is going on or steps to correct ?
