    Branjmb's Avatar
    Branjmb is offline Member
    Aug 2010
    66
    For the future- engines
    Right now I'm completely stock on my 4cyl 92 YJ, and I know this is going to become almost a 10 year project for me.
    I was wondering what you guys would suggest for a future upgrade in engines. More power obviously desired... I just have no idea how one would compare engines and what steps to take to swap.
    Of course all will be figured out when it's time, I'm just kind of curious.
    Jeep Wrangler '92 YJ
    cali_92's Avatar
    cali_92 is offline Senior Member
    Nov 2009
    California
    195
    Re: For the future- engines
    All aluminum v6 supercharged. Corvette perhaps. Lightweight, power, all u need
    Branjmb's Avatar
    Aug 2010
    66
    Okay thanks, I'll keep an eye out for those.
    But what kinds of engines in general are compatible without changing out tons of stuff like transmissions, etc.?
    abe's Avatar
    abe
    abe is offline Senior Member
    Nov 2009
    Sarasota, Florida
    288
    Quote Originally Posted by cali_92 View Post
    ummmm there never has been a corvette with a v6 in it....ever. unless someone would swap one in and why the heck would ne1 do that?
    IF IT DON'T FIT FORCE IT. IF IT BREAKS IT NEEDED TO B REPLACED.
    superj's Avatar
    Feb 2010
    texas
    5,754
    Well, they had straight 6s back in the day but still, not really what you want.
    jfrabat's Avatar
    jfrabat is offline Senior Member
    Dec 2006
    San José, Costa Rica
    1,693
    IIRC, the transmission behind your engine is the AX-5; that engine will not take more than the i$ you currently have on. If it is NOT an AX-5, then you have the peugeot transmission, which is even MORE fragile. Either way, you need a new transmission, and if you are planning on a V6 or V8 (end even an I6!) and/OR bigger tires, I'd recommend also a new rear axle (Dana 44 or Ford 8.8 are popular choices). If you are going in the V8 direction, I would also look into a new front axle...
    '94 YJ 2.5L, Sperwinch EPi 9.0, RE 4" Std Lift, Adv. Ad. SYE, Woody Shafts, Alloy Axles, ARB Lockers, 4.88 gears, 62mm TB & Spacer, 165A Alternator, Griffin 3" Aluminum Rad, Taurus e-fan w/ DC Controller, Borla Cat-Back, Flowmaster hiflow cat, PD Ignition, 19# injectors, Adj. FPR (42PSI), MOPAR cam, Safari Snorkel, 33" BFG KM2, 15" AR wheels, Xenon H4 lights, KC Daylighters & Slimlites, Sony sound, Pavement Ends Targa Top, Hanson Front Bumper, JCR Offroad rear, AtoZ Rockers, Rhino lined Tub.
  1. ??????'s about engines & gas consumption
    By Greeker375 in forum General Chat
    Last Post: 05-10-2009, 11:32 PM
  2. 4.0L Engines
    By Jeepz4Mee in forum Jeep Performance
    Last Post: 05-01-2009, 07:48 AM
  3. Crate Engines
    By murphy07 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 04-10-2009, 04:23 AM
  4. I-6 Engines
    By Jeeper99 in forum General Chat
    Last Post: 02-06-2009, 06:16 PM
  5. Engines cj5
    By sandgrass2000 in forum CJ YJ TJ and JK
    Last Post: 05-10-2005, 10:48 PM
