    cairo10's Avatar
    cairo10 is offline Junior Member
    Oct 2008
    Central KY
    6
    CJ7 exhaust for sb 350 swap?
    I am pulling the I6 and dropping a sb Chevy 350 in its place on our 84 CJ7.
    I'm looking for ideas for the exhaust. I found Hedman has a set of headers for a CJ with a sb 350. What do you recommend for exhaust? I had side pipes on my 76 CJ that had an AMC 304 and really liked them.
    Are there other headers that you'd recommend as well? Something that won't put me in the poor house?
    Thanks,
    Byron
    Central KY
    1984 CJ7 Laredo
    4spd, 258 w/ Weber Carb
    Nothing too fancy, but it rides great!
    black87yj's Avatar
    black87yj is offline Senior Member
    Apr 2007
    wisconsin !
    237
    Re: CJ7 exhaust for sb 350 swap?
    i had fenderwell headers on my 77 cj and loved them but they rust out fast unless you get ceramic.....
    Willy Mudd.slinger Fosbinder
    superj's Avatar
    Feb 2010
    texas
    5,754
    can you do stock manifolds, the ram's head stock manifolds are very good stock manifolds and came on vettes form the factory. i see them on ebay regularly for 50 bucks a set. then run side pipes? i will be so jealous if you run side pipes. i have wanted side pipes on anything since i got my license. i keep getting told that unless they were offered from the factory then i won't pass inspection. that is what kept me from putting them on my 65 mustang.
    Ggg's Avatar
    Ggg
    Ggg is offline Senior Member
    May 2009
    N.W. IL.
    525
    If you have had side pipes and like them well great. I had them and hated driving with them on my 77 CJ5 327. Too loud and stinky with the pipe exit right under my butt.
    I used block hugger style headers, most every header Co. makes that style. I agree with the early rams head style iron manifolds too. Fender exiting headers can be a pain with steering and clutch clearance issues.
    cairo10's Avatar
    Oct 2008
    Central KY
    6
    Thanks! I'll look into the rams head manifold too.
    Several years ago, I had a 76 CJ7 w/ the 304, 3sp, vacuum 4x4 setup. The engine had a performance cam, offenhauser manifold, holley 4bbl, hooker headers and glass packs & side pipes. I actually liked the sound and side exit. While it was fun to drive, I wasn't thrilled with the overall performance setup.
    I'm excited to set this one up with the 350.
    Byron
    Central KY
    1984 CJ7 Laredo
  1. chevy swap? jeep body swap?
    By registration45 in forum CJ YJ TJ and JK
    Last Post: 01-25-2012, 10:56 PM
  2. Exhaust Manifold, or Exhaust Pipe?
    By Operation 4x4 in forum CJ YJ TJ and JK
    Last Post: 02-04-2010, 11:44 PM
  3. New Exhaust
    By fireman32 in forum CJ YJ TJ and JK
    Last Post: 04-09-2007, 07:53 PM
  4. Motor & Trans swap= T Case swap?
    By Joopin in forum CJ YJ TJ and JK
    Last Post: 07-30-2003, 05:17 PM
  5. TJ exhaust swap
    By jhiggins in forum CJ YJ TJ and JK
Tags for this Thread
