05 TJ Intake Air Temp Sensor
Medicjeff66
Greetings!
Being new to the forum and the Wrangler, I need some help.
I have a 2005 TJ, 2.4L, currently all stock. Was getting a trouble code and took to local parts store to have code read. Store told me code was a problem with the Intake Air Temperature Sensor. Went to my mechanic, he verified but wants a ton of $$ to change it. Where is this sensor located on the 05 2.4L?
Thanks for any help.
It should be on the air intake tube close to the throttle body. It is twist locked in. About the easiest thing to replace and should be fairly cheap. I see may posting about rock auto having many OEM parts for less than others.
