91 yj won't start
redneck
I have a 91 yj 2.5L. I parked it for 2 weeks and when to start it to move it. It just cranked. I'm getting spark and gas but won't fire up. Can anyone help me.
Do you have fuel? Have you checked the relays and fuses?
Mmm normally when doesn start is because the battery does not have enough energy, i its not the battery check the fuses.... Is the weater too cold?
Check the injector connector to be sure thats workimg. Also checknyou have the right fuel pressure (it is possible yours is low). Since you have spark, the only other culprit coul be a bad sensor (crank position sensor or cam position sensor would be my first suspects, but I am not too familiar with the TBI system...)
Put some dryer sheets under the dash under the hood and all around the riig. For some reason mice don't like the smell of them and will vacate. Also works good in campers. Doesn't smell musty after setting over the winter.
