JPNinPA
Active member
Short version
P0128 Thermostat Rationality
P0128 JEEP
Description
Indicates that the thermostat monitor has not achieved the required engine operating temperature within a specified amount of time after starting the engine.
Symptoms- CEL
Possible causes
- Insufficient warm up time
- Low engine coolant level
- Leaking or stuck open thermostat
- Faulty MAP sensor
- Engine coolant temperature sensor harness is open or shorted
- Engine coolant temperature sensor circuit poor electrical connection
- Faulty engine coolant temperature sensor When is the code detected?
Coolant temperature does not reach predicted engine coolant temperature within specific time
Tech notes
If cooling system is not leaking and the fluid level is OK, replacing the thermostat usually takes care of the problem.
This one was only 6 mo old
P0128 JEEP
Description
Symptoms- CEL
Possible causes
- Faulty MAP sensor
Tech notes
