Thread: 304 swap
    timgcummins's Avatar
    timgcummins is offline Junior Member
    Jan 2012
    10
    304 swap
    hey guys i need some ideas for a replacement for the stock 304 in my 78 cj7 it has an automatic and quadratrac im thinking maybe a chevy 350??? id like to keep it as easy as possible
    luis's Avatar
    luis is offline Senior Member
    Jul 2011
    suprise az
    634
    The easiest possibility would be just rebuilding your old one and dropping it back in. I have a tj so I wouldn't know what could bolt up to your drive train. But I'm sure a 350 would fit. But rebuilding would be easiest. I'm guessing the knocking coming from your bottom end didn't turn out anything good
    Jan 2012
    10
    I'm just way too inexperienced to take it all apart. I bit off way more than I could chew haha
    superj's Avatar
    Feb 2010
    texas
    5,754
    Re: 304 swap
    put a 318 in or a 360
    flatie46's Avatar
    flatie46 is offline Senior Member
    Jul 2010
    Russellville TN
    1,047
    Re: 304 swap
    Find anthor 304, you could prbably buy a running CJ5 and buy it engine and all cheaper than you could adapt and swap with less the hassel. Then make your money back selling off the extra's. Or find an FJS to pull the engine from. 360's are a bolt in if you had a 304.
    82cj7son's Avatar
    82cj7son is offline Senior Member
    Jun 2011
    central florida
    186
    http://www.rebuilt-jeep-engines.com/
    kinda cheap. 7 yr warranty. might be something to research
  7. #7
    Saddle Tramp's Avatar
    Saddle Tramp is offline Senior Member
    Apr 2009
    Vancouver USA
    612
    Re: 304 swap
    Do yourself a favor and just do a long block swap. The average mechanic can do the job in a weekend; maybe even bump up to an AMC 360.
  8. #8
    big_o_tom's Avatar
    big_o_tom is offline Senior Member
    Mar 2008
    156
    Re: 304 swap
    Ive got a decent 304 too. I think it needs a valve jod on the heads, costs about a $100 here, or you could swap your heads onto it.
  9. #9
    bch-jeeper's Avatar
    bch-jeeper is offline Junior Member
    Jul 2009
    11
    Re: 304 swap
    swap a AMC 390 or 401 fits same as 304.
  10. #10
    big_o_tom's Avatar
    Mar 2008
    156
    Re: 304 swap
    Ive got a mildly built 401 in my cj-7. Way to much power for a jeep in my opinion, but sure is a blast to drive. I may end up puting 36-38" tires on it so I will probably need the extra power then. A 360 would be another option, theyre plentiful too.
  11. #11
    Apr 2009
    Vancouver USA
    612
    Re: 304 swap
    Quote Originally Posted by bch-jeeper View Post
    The AMC 401 is getting pretty hard to find. Most of the major rebuilders need you to send them your block first as they donít have a rebuilt one in the warehouse. The 390 will be even harder to get. Not saying it canít be done but it can take a while. I haunted Craigís List and the like for over a year to come up with mine and then I had to drive to the other side of the State to pick it up. Thatís why I suggested maybe bumping up to a 360 as they are still fairly plentiful.
  12. #12
    superj's Avatar
    Feb 2010
    texas
    5,754
    Re: 304 swap
    i found out that you have to use amc v8s, not dodge v8s. the old amc v8s have a different bolt pattern then the new dodge v8s and they are balanced differently, using the flywheel versus internally balanced so you have to get the correct flywheel also
  13. #13
    Apr 2009
    Vancouver USA
    612
    Re: 304 swap
    Quote Originally Posted by superj View Post
    Yep, itís got to be an AMC and you have to use the right flywheel but they are available for any parts house. Look for the motor size cast into the side of the block below the motor mounts.
  1. chevy swap? jeep body swap?
    By registration45 in forum CJ YJ TJ and JK
    Last Post: 01-25-2012, 10:56 PM
  2. 4.2 swap to 4.0
    By joejoe87jeep in forum CJ YJ TJ and JK
    Last Post: 07-08-2009, 09:40 PM
  3. swap or not???
    By yjmudder90 in forum CJ YJ TJ and JK
    Last Post: 03-23-2009, 02:47 AM
  4. swap
    By 85xj in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 12-10-2003, 10:23 PM
  5. Motor & Trans swap= T Case swap?
    By Joopin in forum CJ YJ TJ and JK
    Last Post: 07-30-2003, 05:17 PM
Tags for this Thread
