Thread: Doors
    clydethepirate's Avatar
    clydethepirate is offline Senior Member
    Jul 2011
    763
    Doors
    Ok,
    Still working on rebuilding these full steel doors I bought for my YJ.
    The doors are off of a 84 CJ.
    I thought.......
    What if I put all of this work into these doors and they happen to Not fit so I tried the on today.
    Everything looks great except there's about a 3/8 gap at the top of the windshield.
    The bottom fits nicely but the top has a gap.
    Someone told me I can adjust the windshield frame at the top.
    I said.... those bars across the top are holding it in place
    He said........ it can still be adjusted, loosen the three bolts at the botton of the windshield frame and the two at the top, pull it back where I need it and tighten everthing up again...........
    Anyone ever heard of this before? (I'm not believing it)
    jps4jeep's Avatar
    jps4jeep is offline Moderator
    Dec 2002
    Boston
    6,657
    Re: Doors
    disregarding the latching mechanism, CJ7 and YJ doors are dimentionally the same and should fit as such.
    EDIT: if it doesn't leak, then just run them, jeeps are exactly known for stellar body gaps and straight lines
    It used to be a jeep Thing,
    But all that stuff broke
    -Johnny-
    Ggg's Avatar
    Ggg
    Ggg is offline Senior Member
    May 2009
    N.W. IL.
    525
    Re: Doors
    I have used washers as shims at the top between the windshield frame and the roll bar supports to change the windshield angle a little to close the gap.
    Steven Gable's Avatar
    Steven Gable is offline Junior Member
    Nov 2010
    West Chester, PA
    13
    I had the same problem with my doors. If you loosen the torx safety bolt on top of the roll cage bar between the windshield and the main hoop, you can pull back on the top corner of the windshield and have someone tighten the bolt down. The bolt is ne'er the main hoop. It goes through a slot, and not just a whole, which enables this adjustment.
    Jul 2011
    763
    Re: Doors
    I found that and it worked great.
    Now everything lines up like it should.
    TrailRatedRN's Avatar
    TrailRatedRN is offline Senior Member
    Aug 2011
    Springboro, Ohio
    1,869
    Quote Originally Posted by jps4jeep
    Heh... Heheh... Heheheh...
  1. WTT black half doors with uppers for full doors
    By JK KiD in forum Items for Sale, Trade, or Give Away
    Last Post: 11-16-2011, 03:57 PM
  2. Trading out full steel doors for half doors on 2000
    By d3brown4jeep in forum CJ YJ TJ and JK
    Last Post: 06-29-2011, 10:36 AM
  3. trade half doors and 5 new tires for full doors +CASH$$$ yj
    By diego88m in forum Items for Sale, Trade, or Give Away
    Last Post: 07-05-2009, 01:59 AM
  4. Replies: 3
    Last Post: 02-28-2005, 05:25 PM
  5. Question about upper hard doors for half doors.
    By Craig in forum CJ YJ TJ and JK
    Last Post: 02-09-2005, 04:03 PM
