    clydethepirate's Avatar
    clydethepirate is offline Senior Member
    Jul 2011
    763
    Headlights Flashing
    Out last night and my headlights Kept going out and then back on.
    They would go out for a 2 to 3 seconds and then come back on but the strange thing is its only the headlights. Tail lights, Rear sidemarkers, (Not sure about front markers) and the instrument lights stayed on.
    Anyone got any ideas where to start looking for the problem?
    bugleboy's Avatar
    bugleboy is offline Senior Member
    Nov 2011
    Lee County Florida
    1,724
    had the same problem in my cherokee, ended up being my headlight knob was bad an had my lights flashing when i hit bumps on the highway or when i was up to speed, i tested it by going to a parking lot with a speed bump and driving over it several times
    superj's Avatar
    Feb 2010
    texas
    5,754
    Re: Headlights Flashing
    yjs are famous for the switch going bad
    Bounty__Hunter's Avatar
    Nov 2002
    Southern Illinois
    13,425
    Headlight switch, cheap and easy to replace, the parts stores carry them.
    Jul 2011
    763
    I will give the new switch a try tomorrow
    carnuck's Avatar
    carnuck is offline Senior Member
    Jan 2009
    Seattle
    917
    If you have upgraded your lights, the factory switch/wiring don't seem to like it. Could be the highbeam switch too.
    '87 Comanche 4x4 lifted 5 1/2" on 33" tires 4.0L/AW4/NP242 $3500
    Perfect combination but too small to haul my Grand Kids and wife in.
  7. #7
    Turbogus's Avatar
    Turbogus is offline Senior Member
    Nov 2005
    Albany~town, Oregon
    1,328
    Years ago I added 190/100W H4's to "Easy Bake" my black panel van, and immediately had this issue, I added a relay for each side and it cleared right up, later I altered the wiring as in those years of vans, Ford used 18 gauge wiring for the headlights, I upgraded from relay to connectors with 12 gauge and it's been bulletproof for over a decade.
    Quick fixes are so named for how long they stay fixed.
    If you run out of gas, no matter which way you decide to push, the closest gas station will always be uphill and in the other direction. Corollary: The likelihood of running out increases when all of the nearby gas stations are closed.
    The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep.
    We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch).
  1. '93 YJ flashing(?) 4x4 dash indicator
    By M G D in forum CJ YJ TJ and JK
    Last Post: 11-27-2010, 10:00 AM
  2. Lights flashing randomly on Grand Cherokee
    By PlasticNerd in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 11-08-2010, 03:21 AM
  3. oh monitor flashing
    By ka041a in forum CJ YJ TJ and JK
    Last Post: 11-20-2008, 03:50 PM
  4. ECU flashing + Texas to Washington
    By jaymz77 in forum CJ YJ TJ and JK
    Last Post: 04-24-2006, 07:27 PM
  5. Side markers not flashing (post split)
    By red89yj in forum CJ YJ TJ and JK
    Last Post: 01-23-2005, 07:38 PM
