Your going to need to seperate the hub. The bearing is press on from the outside end of the axle. The safest/correct way to remove the bearing is with a bearing remover clamp setup or a press. If you are upgrading to a solid axle type, you could just use a cut off wheel on the bearing to get the plate off.
