    jackobotz's Avatar
    jackobotz is offline Member
    Apr 2009
    Philadelphia, Pa
    47
    leakimg diff fluid
    90 yj front axle( dana) 30 is leaking out end of tube. any idea if these are the right seals ?
    Alloy Usa Axle Tube Replacement Inner Seal For 11105 & 11106 ALL-11109
    Jack
    PoliceMonkey161's Avatar
    PoliceMonkey161 is offline Senior Member
    Dec 2011
    Ellicott City
    589
    If you have USA Alloy axles, this would be the mud seal, the stock axle does not use it. I think you want this:
    26 Axle Oil Seal 1987-1995 ALL 8121781 $2.99
    The link did not work, but go to the YJ section at Morris, front differential/Dana30 and look at #26. I did a write up on rebuilding a wide track Dana30 in the "how to section" and the seal replacement is covered.
    Dec 2011
    Ellicott City
    589
    Sorry, was just looking at the diagram at Morris, it can be found under YJ, axle front Dana30. The part you listed is the equivalent of #21, intermediate seal. You will need to know the diameter of your axle shafts if they are stock.
    jackobotz's Avatar
    Apr 2009
    Philadelphia, Pa
    47
    Re: leakimg diff fluid
    I have a friend who owna an ammco across the etreet, I went to get him to order part. There is a 95 wrangler there with a blown engine, has a 44 in front and 8.8 in rear. he is not going to fix it, trying to buy it for parts.
    Jack
  1. Where do you put clutch fluid in an 89 YJ?
    By Guest in forum General Chat
    Last Post: 02-01-2014, 08:38 AM
  2. diff fluid? with arbs
    By dmille4.6 in forum CJ YJ TJ and JK
    Last Post: 07-09-2009, 11:13 PM
  3. Diff fluid with a Detoroit locker?
    By Craig in forum CJ YJ TJ and JK
    Last Post: 09-27-2005, 06:32 PM
  4. Fluid Change/Transmission & Diffs?
    By Sparky-Watts in forum CJ YJ TJ and JK
    Last Post: 09-11-2005, 06:29 PM
  5. Power Steering Fluid Change
    By Doey7 in forum CJ YJ TJ and JK
