Thread: Antifreeze Leak
    RBREECE's Avatar
    RBREECE is offline Junior Member
    Jan 2014
    1
    Antifreeze Leak
    I replaced a a water pump on my 1997 Jeep Wrangler, after completing and making sure that I had the new water pump installed and everything replaced and sealed, and started to refilled the radiator with antifreeze it is a steady drip, I have also replaced, the lower radiator hose and theromistate also. It looks like the drip is comming behind the harmonic balencer, is there something that I have missed?
    Thanks you
    Randy B.
    greg92jeepxj's Avatar
    greg92jeepxj is offline Official Supporter
    Apr 2013
    Staten Island n.y.
    2,000
    Re: Antifreeze Leak
    To be certain of exactly where the leak originates , see if you can rent a cooling system pressure tester from autozone . It fastens to the radiator where the radiator cap goes . You then pump it up to the cooling system pressure marked on the radiator cap . The pressure wil force out antifreeze from the leaking area and you will be able to find where to correct the leak.
    69jeepcj's Avatar
    69jeepcj is offline Senior Member
    Feb 2012
    Cincinnati, Ohio
    1,993
    Re: Antifreeze Leak
    The water pump gasket just may have not sealed, too much rtv or not enough or got smeared off putting the pump back on. Ive had to redo gaskets more than once because it didn't seal, especially on axle covers.
    Apr 2013
    Staten Island n.y.
    2,000
    Re: Antifreeze Leak
    Yes , it's very possible the gasket could be leaking . These days , the lack of quality of replacement parts and their imperfect machined surfaced and the less than quality gaskets they include , very possible. Gasket sealer dosen't always close the gap , rtv is the only way to build up and seal any voids . Just never go overboard , never want any to seep into the part , just enough to seal is all that is needed.
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,582
    When I replace any gaskets in the cooling system i dress them, assemble them and let it sit for an hour after tightening down.
    Second if you have a black light from Halloween, you could use it to illuminate the antifreeze and track where it leakin.
  1. Engine/Antifreeze Heater LEAKING!!!
    By jeepgeek in forum CJ YJ TJ and JK
    Last Post: 04-11-2009, 10:28 AM
  2. Distributer is leaking
    By TerryMason in forum CJ YJ TJ and JK
  3. leaking
    By mudduck in forum Cherokee, Commander, Wagoneer and Liberty
  4. Distributor leaking oil
    By tangel in forum CJ YJ TJ and JK
  5. Oil leak?
    By grooveman in forum CJ YJ TJ and JK
