93 YJ radiator issue/ maybe
Squancho
pulled in driveway all the coolant came out of the drivers side transmission cooler nipple? On drivers side bottom of radiator. No over heating, never had a
prob, nothing came out of the one on pass side. Dude in a jeep group says i need new radiator? Can i not just plug it?
93 yj 4.0 5 speed
pulled in driveway all the coolant came out of the drivers side transmission cooler nipple? On drivers side bottom of radiator. No over heating, never had a prob, nothing came out of the one on pass side. Dude in a jeep group says i need new radiator? Can i not just plug it? 93 yj 4.0 5 speed
No you can't plug it. If driver side radiator at the outlet. This is a known failure point. First check your radiator hose to be sure this didn't fail. Using over the counter bottle of fix it will do more damage to the engine than it will help fix the radiator.
