1991 yj instrument panel not working.
Brask12
Hi I have a 91 yj that I just purchased. The only light that works on the instrument panel is the right turn signal and maintenance required. What could this be? I have checked the fuse block under the dash and they seem to be good. All the other Guage lights work fine, just the instrument lights. The stock radio has been snipped and relocated in the center counsel with a new power wire ran to the battery.
The YJ dash is pretty easy to work on. Check the circuit panel providing power to the bulbs for broken circuits, and check for bad bulbs.
