Greasing Slip Joints
Ludsjeep
Have lubed rear slip joint on Jeep TJ 2.5. Looks as though there is a slip joint up front. Should it be greased as well?
Grease every zerk fitting. Should be one in the middle of your front driveshaft.
Be nice if fittings were on ujoints and drive shaft but none are there. My concern is the front slip joint which has s rubber boot...
There were u joints that with seek fittings. I don't know if they are still available. With TRE, ball and U-joints there may be mfg specific grease. Spicer has a special grease that does not result in corrosion from the grease itself. Just an additional FYI
