Page 1 of 2 12 Last
    Nickg's Avatar
    Nickg is offline Junior Member
    Jan 2017
    17
    Intermitent to no spark 95 wrangler
    Hey guys i need some help, i traded for a 95 jeep wrangler and when i got it from the guy it was running and sounded great, but i brought it home on a trialer and when i got home it started giving me trouble starting up. The guy told me that it had trouble starting in the cold but i found its having trouble even when its warm out. So i checked for spark and it wasnt getting spark everytime. Sometimes when you crank it there would be spark and then other times there would be none at all. I replaced the spark plugs, wires, cap and rotor, ignition coil, pickup coil and battery. It still would only crank usually, occasionally it would get spark and start to turn over then choke out like the spark just stopped. Now when i turn the key all it does is crank and i cant get any spark out of it. Sometimes when i turn the key it doesnt even crank but then if i cycle the key a couple times it will crank again but still no spark.
    If you guys have any incite on this please let me know ive been trying everything to figure this out and im out of ideas. Thank you
    Nickg's Avatar
    Jan 2017
    17
    Re: Intermitent to no spark 95 wrangler
    Sent from my SM-G920V using Jeepz.com mobile app
    Nov 2016
    48
    Check for a good ground between the battery and the frame. Then check for a good ground between the battery the engine block.
    Then check where positive cable terminates at the battery and at the starter.
    Thoroughly inspect the battery cables positive and negative from the battery all the way to their destinations to make sure they're not damaged anywhere and they are of sufficient size for the current draw and the distance they need to travel...
    Then check the hot lead ignition switch to the coil making sure it is all the proper size wire and well terminated. Are you using a ballasted coil? Is it an external ballast for an internal ballasted coil? Is there a bypass wire for the externally ballasted coil if you have that type...? If so, make sure that's working properly.
    That should be plenty to look at for a while...;-)
    Sent from my Z970 using Tapatalk
    Nickg's Avatar
    Jan 2017
    17
    Thank you i have all good grounds there and the positive cable is good. The wires are all correct sizes
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,021
    95 wrangler yj no spark
    CPS and CPK go bad. They both set the spark. I'd check both out. If replacing use only OEM brand parts. Start with the CPK they are intermittent before full fail.
    Above is good advice battery, grounds and connections could have you chasing your tail.
    JPNinPA
    Using Jeepz.com app
    Nickg's Avatar
    Jan 2017
    17
    Thank you ive checked both and niether are bad. This issue has my mind boggled
  7. #7
    superj's Avatar
    Feb 2010
    texas
    5,754
    Re: 95 wrangler yj no spark
    I would say that crank sensor. Someone just went througj this recently and theirs checked good but when they put a replacement in, jeep fired up perfectly. Thats always been the trouble on my xj cherokee and yj wrangler. Also, once on my zj grand cherokee. All had the good ol 4.0
  8. #8
    RJ INA YJ's Avatar
    RJ INA YJ is offline Junior Member
    Jan 2017
    2
    I would check the timing, particularly the timing belt.
    RJ
  9. #9
    RJ INA YJ's Avatar
    Jan 2017
    2
  10. #10
    superj's Avatar
    Feb 2010
    texas
    5,754
    There is no timing belt.
    Are we talking the jeep in the pic? It doesn't look like a 95 yj
  11. #11
    Nov 2016
    48
    The reason I had you look at all of the high tension leads first is because the last part of your inquiry where you say sometimes it won't even crank - you have to cycle the key a few times...
    This is key. You need to solve that problem before you move on. Check to make sure the ignition switch is not broken. Check to make sure the starter solenoid is working properly. Check to make sure are your Park neutral safety switch is working correctly for automatic or your clutch lever switch for a stick...
    You've got to get that to work reliably before you can go on to checking for spark. That's why I keep going back to your high tension leads. They may look okay but perhaps there's a bad connector in there somewhere if all of the other things about that I just explained check out okay.
    BTW, for testing purposes, I will use jumper cables to create solid connections when there is question as to whether or not the existing cables are good
    RR
  12. #12
    Nickg's Avatar
    Jan 2017
    17
    It is a 95 yj the previous owner took the hood off and put on i believe a 70's cj hood on it
  13. #13
    Nickg's Avatar
    Jan 2017
    17
    Quote Originally Posted by superj View Post
    Thank you. Im gonna pick up a new sensor this week and try it out
  14. #14
    Nickg's Avatar
    Jan 2017
    17
    Quote Originally Posted by RestorationRides View Post
    RR
    I did check all that im going to go through it all again
  15. #15
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,021
    Quote Originally Posted by Nickg View Post
    OEM. Only. Check rock auto. Com
    Regards,
    JPNinPA
    Sent using TapTalk
  16. #16
    superj's Avatar
    Feb 2010
    texas
    5,754
    which engine was in it? I just reread everything and noticed we don't know which engine you have. hopefully, its 6 cylinder because everything I have been saying
    is for the 6
  17. #17
    greg92jeepxj's Avatar
    greg92jeepxj is offline Official Supporter
    Apr 2013
    Staten Island n.y.
    2,000
    Agree with above post . The 2.5 liter or the 4.0 ?
    Also , the second post shows a CJ7 trailered . You mentioned a trade , was it the CJ for the YJ ?
  18. #18
    superj's Avatar
    Feb 2010
    texas
    5,754
    I asked the same thing. he said the previous owner did a cj swap on the front
  19. #19
    Apr 2013
    Staten Island n.y.
    2,000
    Guess he didn't like the square headlights ? Well , you know he's got a good jeep now ! The looks of a CJ and the integrity of a YJ wrangler ! Can't go wrong . Nice Camo too !
  20. #20
    superj's Avatar
    Feb 2010
    texas
    5,754
    I like the square headlights on the yj. it separates the yj from the rest. you can always tell the original wranglers by the square headlights.
Page 1 of 2 12 Last
  1. No Spark.. Need diagnostic help... 95 wrangler yj
    By Bryan Sorrentino in forum CJ YJ TJ and JK
    Last Post: 08-03-2016, 12:53 AM
  2. '97 Wrangler has no Spark
    By BigD727 in forum All other Jeep models
    Last Post: 03-21-2015, 06:47 PM
  3. no spark 92 wrangler 2.5L 4 cylinder
    By kessel-31 in forum CJ YJ TJ and JK
    Last Post: 08-08-2014, 07:25 AM
  4. 90 wrangler 4.2 starts, after 5 sec. loses spark
    By tailights24 in forum CJ YJ TJ and JK
    Last Post: 03-04-2009, 11:40 PM
  5. 94 wrangler no spark at distributor
    By ranger in forum Jeep Electronics and Audio
    Last Post: 11-27-2008, 11:45 AM
