Page 1 of 2 12 Last
    JMoring's Avatar
    JMoring is offline Junior Member
    Jan 2017
    9
    Suspension lift or body lift
    My sons 97 Wrangler TJ needs new shocks and bump stops. it has a 3 inch lift kit but I don't know if it has a suspension lift or a body lift. How do you tell the difference?
    78cj71ton's Avatar
    78cj71ton is offline Senior Member
    Dec 2016
    266
    Re: Suspension lift or body lift
    Google body lift TJ images
    Sent from my SGP561 using Jeepz.com mobile app
    xt master's Avatar
    xt master is offline Senior Member
    Nov 2008
    NE-PA
    1,656
    Easy look between the rear bumper and the body. Should have body mounts factory about 3/4 inch...body lift they would be bigger depending on the lift size.
    Sent from my VS880 using Jeepz.com mobile app
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,021
    Agree with above. Look at the distance between the frame and body in the rear wheel well. There should be 3/4 in gap,
    I certainly hope it's a suspension lift or a mix of 1 in body and 2 in suspension.
    Three in body lift is dangerous. Imho.
    JPNinPA
    Using Jeepz.com app
    Nov 2016
    48
    Curious here, JPNinPA. Why do you think a 3 inch body lift is dangerous (any more so than a 3 inch suspension lift)...?
    RR
    Sent from my Z970 using Tapatalk
    78cj71ton's Avatar
    Dec 2016
    266
    It isnt really but when your off you don't have the articulation so you could end up on your side easier with the body lift only. More suspension, keep the body low, make clearance for tires
    Sent from my D6708 using Jeepz.com mobile app
  7. #7
    Nov 2016
    48
    Okay. Makes sense to me. The only drawback, the way that I see it, is that the overall vehicle's center of gravity will be higher with an all suspension lift as opposed to a mixed lift of the same height. This would make it less desirable for stability reasons ON Highway as well as at higher speeds off road.. :-(
    Sent from my LG-H631 using Tapatalk
  8. #8
    78cj71ton's Avatar
    Dec 2016
    266
    Only thing is, is that the engine in your rig doesn't weigh much
  9. #9
    78cj71ton's Avatar
    Dec 2016
    266
    My jeep handle pretty good. I went spring over and 2 inch body. I want to take the body lift out. If you can manage to get a little more upward travel out of your rig and make clearance for tires. That us your best bet. As far as center of gravity is concerned.
  10. #10
    78cj71ton's Avatar
    Dec 2016
    266
    You want it to scwat as far as it can. Lots of work
  11. #11
    Nov 2016
    48
    I think it would be interesting to get a weight breakdown between the chassis and and interior components as compared to the drive line and frame. I suspect the majority of the weight is in the drive line and frame of the vehicle thereby making the focus of better CG keeping the frame lower... RR
  12. #12
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,021
    Quote Originally Posted by RestorationRides View Post
    RR
    First consideration is linkages and pedals(older vehicles)... The possibilities for binding or not having the clearances for the through getting knocked out of gear...
    Second is the amount of torque put on the longer bolts and frame...needed to hold the body and frame together. There is a larger potential for the body to actually move on the frame and over time breaking a bolt. Especially when braking.
    Regards,
    JPNinPA
    Sent using TapTalk
    Edit: didn't mention I agree with the articulation and COG leafing to rollover when rock crawling or sharp turns.
  13. #13
    78cj71ton's Avatar
    Dec 2016
    266
    Suspension suspension 👍👍👍
  14. #14
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,021
    Like this?like this?
    Regards,
    JPNinPA
    Sent using TapTalk
  15. #15
    78cj71ton's Avatar
    Dec 2016
    266
    Now make wheel base longer and wider.
  16. #16
    78cj71ton's Avatar
    Dec 2016
    266
    I know my body isn't heavy at all
  17. #17
    78cj71ton's Avatar
    Dec 2016
    266
    Hard to keep it low with out building a custom rig
  18. #18
    78cj71ton's Avatar
    Dec 2016
    266
    You can probably get the drivetrain down lower relatively easy I imagine. Couple inches
  19. #19
    TerryMason's Avatar
    TerryMason is offline Administrator
    Dec 1999
    Virginia Beach VA
    7,602
    Quote Originally Posted by JMoring View Post
    First is to find if you have a body lift or not. In this picture, the body lift is the dark black piece. It's actually a spacer that sits on top of your factory body mounts
    Name:  15739d1461006629t-terrymason-s-2005-jeep-tj-build-06-body-mount-place-terrymason-jeep-wrangler-t.jpg
    If you only have a body lift, then you can buy stock shocks. If you have a suspension lift, then you should buy shocks and bump stops made for a 3 inch suspension lift.
    I run Rough Country shocks, just because they were cheap, and I'm happy with them.
    Shocks & Struts | Rough Country Suspension SystemsŪ
    There are plenty of other brands out there, so read a bit before you buy.
  20. #20
    78cj71ton's Avatar
    Dec 2016
    266
    I like that diagram gonna keep that one😀😯
Page 1 of 2 12 Last
  1. Body Lift or Suspension Lift?
    By VegasTrailRider in forum CJ YJ TJ and JK
    Last Post: 08-18-2010, 10:24 PM
  2. yj body lift and suspension; need guidance
    By usafacadet09 in forum CJ YJ TJ and JK
    Last Post: 09-21-2009, 10:04 AM
  3. Body vs suspension lift
    By cbanks in forum CJ YJ TJ and JK
    Last Post: 05-19-2009, 08:35 PM
  4. suspension or body lift
    By TerryMason in forum CJ YJ TJ and JK
  5. YJ with just a body lift, no suspension lift
    By Snitty in forum General Chat
