    cjsit960's Avatar
    cjsit960 is offline Junior Member
    Apr 2014
    29
    1979 CJ7 Quadra Trac with TH400 - With a Chevy 350 Vortec Motor- Flex Plate question
    SORRY I AM TALKING ABOUT THE SKIP PLATE TO MOUNT THE TRANNY ON.
    The frame on the 1979 CJ7 is Rotted , I have a none rotted 1985 CJ7 Frame that i sand blasted and POR15 It which i am using.
    I am using everything from 1979 CJ7 but the 6 Cyclinder motor, MY question is with the SKID PLATE for the tranny and quadra track,
    Will it mount to the 1985 CJ7 Frame or do i have to weld brackets on it to support it and get the driveshafts all lined up-
    There are a few nuts on the 1985 frame underneath but i don't think the flex plate will mount correctly
    for the tranny.- I guess i just have to line it all up and see-
    First Picture is the 1985 CJ7 Frame
    Thx
    Attached Thumbnails Attached Thumbnails 1979 CJ7 Quadra Trac with TH400 - With a Chevy 350 Vortec Motor-  Flex Plate question-1292.jpg
    1979 CJ7 Quadra Trac with TH400 - With a Chevy 350 Vortec Motor-  Flex Plate question-11-1-2016-015.jpg
    1979 CJ7 Quadra Trac with TH400 - With a Chevy 350 Vortec Motor-  Flex Plate question-11-1-2016-013.jpg
    78cj71ton's Avatar
    78cj71ton is offline Senior Member
    Dec 2016
    266
    Re: 1979 CJ7 Quadra Trac with TH400 - With a Chevy 350 Vortec Motor- Flex Plate ques
    Chevy 350 is zero balance flex plate. You might need a torque converter and an adapter for the engine to tranny. You might consider a chevy transmission with overdrive
    Sent from my SGP561 using Jeepz.com mobile app
    cjsit960's Avatar
    Apr 2014
    29
    Thx I got the adapter from Novak they are so helpful with the setup.
    https://www.novak-adapt.com/catalog/...on/gm/kit-374/
    Sorry My fault I am talking about the skid plate for the tranny to mount to.
    78cj71ton's Avatar
    Dec 2016
    266
    Yeah they do a lot of that stuff. Also advanced adapters has a lot of cool stuff
    78cj71ton's Avatar
    Dec 2016
    266
    I used the stock skid and drilled new holes for transmission mount
    78cj71ton's Avatar
    Dec 2016
    266
    I'm replacing mine soon with a with a prefabbed dyi HD plate stock one is a little thin
  7. #7
    cjsit960's Avatar
    Apr 2014
    29
    Thx I may tried that- or cut it and weld a to it . if you look at the picture it not level
    1979 CJ7 Quadra Trac with TH400 - With a Chevy 350 Vortec Motor-  Flex Plate question-11-18-2016-004.jpg
  1. Replies: 21
    Last Post: 02-19-2017, 10:26 AM
  2. Lift for wj with quadra trac 2
    By 04wjv8 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 03-29-2016, 06:31 AM
  3. Quadra-trac q's
    By ski79cj7 in forum CJ YJ TJ and JK
    Last Post: 07-31-2013, 01:05 PM
  4. CJ/Chevy Motor Question?
    By jps4jeep in forum CJ YJ TJ and JK
    Last Post: 06-13-2005, 07:21 AM
  5. Selec-Trac vs Quadra-Trac vs Quadra-Drive
    By erhild in forum Cherokee, Commander, Wagoneer and Liberty
