Losing power and won't rev
How many miles are on it? When was it tuned up last? A plugged catalytic converter can cause those symptoms.
I am guessing cat or muffler is clogged up. how warmed up is it when it does this? when you start the jeep, go feel how the exhaust is coming out the pipe, then when it starts running out of power, go feel how much is coming out. listen to it also. when you start it, it is probably pretty mellow and smooth. if it sounds forced and faster when the jeep is losing power, it is for sure a plugged cat or muffler.
I think mark may be on the money here. Let us know which O2 code your getting.
I believe that you have 4 O2 sensors, 2 upstream and 2 downstream. The downstream sensors are responsible for monitoring the health of your cat.
P0432 - Catalytic converter efficiency
