    mmello13's Avatar
    mmello13 is offline Senior Member
    Nov 2016
    106
    07 wrangler stops working
    Any idea? My gf has an 07 wrangler x and twice her jeep won't attempt to turn over jumps don't work all gauges are fine but sometimes they don't move head lights work alarm worked but wouldn't let me shut it off and the doors wouldn't unlock with the key fob. We had to reset her computer. Any fixes to this problem? We want to get rid of it and get her a newer one. But money. Haha
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    3,574
    Re: 07 wrangler stops working
    First check the battery. Get it load tested and be sure it has clean terminals. If it is serviceable have them check it and adjust when load testing.
    Next clean the connectors and the opposite ends of the wires that connect to the battery. It should be at least one power and two grounds.
    When you reconnect a battery be sure the connectors are shining and tight fitting.
    If you turn the key, do you always, sometimes or never get the dash lights to light? Do you hear the fuel pump prime? It sounds like a little motor running and lasts a few seconds.
    When you turn the key to start does the starter try to turn the engine or nothing? When doing this does the lights dim or the battery voltage dip heavily below 12V? Does the trip odometer reset?
    After the battery and connections common failures that keep you from starting are bad starter, bad ignition switch and a bad crank position sensor.
    Occasionally the neutral safety switch may be misaligned or bad.
    Is the security alarm factory or after market?
    Regards,
    JPNinPA
    Sent using TapTalk
    mmello13's Avatar
    Nov 2016
    106
    Battery is clean and the jeep started right up after resetting the computer. The gauges all moved for me when I first got to her jeep. Lights turned on fuel pump primed after resetting the comp too. But before that there was no noise to attempt to start to priming of the fuel pump but the lights did turn on.
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    3,574
    Again I'd have the battery load tested. Then get a new crank position sensor. Be sure it is an OEM sensor with the paper gasket the on the tip
    JPNinPA
    Using Jeepz.com app
    mmello13's Avatar
    Nov 2016
    106
    Ok I'll look into it. Where does the crank position sensor go and where is the neutral safety switch?
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    3,574
    The crank sensor is on the bell housing it is also caked CKP.
    You could also pull the starter and have it checked.
    And I assumed you checked all fuses. Being it starts occasionally or once after not it is not a fuse. But checking is free and fuses are cheap.
    The neutral safety switch is on the transmission. It senses your jeep is in park or neutral before starting. I think the easiest test is to place a fuse in the socket marked NSS bypass or neutral bypass... It is dangerous to leave it in there. Should you try starting with the trans in gear the jeep will lurch or move.
    Regards,
    JPNinPA
    Sent using TapTalk
  1. 2010 Liberty Tail lights working, brake lights not working
    By 10liberty in forum Jeep Electronics and Audio
    Last Post: 08-06-2016, 09:52 PM
  2. Replies: 0
    Last Post: 07-07-2012, 06:30 PM
  3. Extended Wrangler Spare Tire Bump Stops
    By TerryMason in forum Accessories
    Last Post: 05-07-2012, 11:13 PM
  4. windshield wipers quit working 2003 wrangler
    By broderk in forum CJ YJ TJ and JK
    Last Post: 06-02-2008, 07:35 PM
  5. Like it ever stops.
    By jps4jeep in forum General Chat
    Last Post: 07-11-2005, 11:37 AM
