    YJ-BLAKE's Avatar
    YJ-BLAKE is offline Junior Member
    Mar 2017
    13
    Angry 1988 YJ engine sputtering
    i have a jeep wrangler 2.5 liter with around 140,000 miles on it. the problem is when i try to accelerate my engine seems to sputter and hesitate for a few seconds. it loses lots of acceleration and it sounds like popping or a bubbling, and a very harsh exhaust smell is noticeable when it happens. my emissions maintenance light has been on since i got it, witch leads me to believe that it could be o2 sensor? but i am not 100% sure.
    i just recently bought it and i have replaced thermostat, motor mounts, and valve cover gasket.
    xt master's Avatar
    xt master is offline Senior Member
    Nov 2008
    NE-PA
    1,532
    Re: 1988 YJ engine sputtering
    I would start with the basics tune up and fuel filter rotor and cap. If it still persists is it fuel injected or carberated. Also could be fuel pump issues.
    Jeep! not just a vehicle a way of life.
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    3,342
    Agree. Check for a blocked exhaust or CAT.
    Describe the foul exhaust smell? Any color to it?
    JPNinPA
    Using Jeepz.com app
    YJ-BLAKE's Avatar
    Mar 2017
    13
    Quote Originally Posted by xt master View Post
    the cap was recently replaced i've done mostly everything for a complete tune up besides plugs and wires witch im doing today. its fuel injected by the way.
    YJ-BLAKE's Avatar
    Mar 2017
    13
    JPNinPA
    Using Jeepz.com app
    how to i check for a blocked cat. when it sputters it usually blows out a puff of white smoke. i have a slight leak of exhaust into the cab but it gets waaay worse when the engine sputters.
    Thank you
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    3,342
    I cud checking for a intake leak and the TPS.
    Still describe the exhaust smell.
    JPNinPA
    Using Jeepz.com app
  7. #7
    YJ-BLAKE's Avatar
    Mar 2017
    13
    JPNinPA
    Using Jeepz.com app
    It smells very potent, burning fuel
  8. #8
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    3,342
    Quote Originally Posted by YJ-BLAKE View Post
    Thank you
    Easiest is remove the upstream sensor from the exhaust leaving a hole. See if the problem persists with less restriction.
    JPNinPA
    Using Jeepz.com app
  9. #9
    xt master's Avatar
    Nov 2008
    NE-PA
    1,532
    If it seems to be running rich..causing the fuel smell in the exhaust I would look into spark or air flow. Make sure nothing is clogged in the air box and air filter is clean. Could also be a bad mass air flow sensor.
  10. #10
    YJ-BLAKE's Avatar
    Mar 2017
    13
    JPNinPA
    Using Jeepz.com app
    The o2 right after the headers?
  11. #11
    YJ-BLAKE's Avatar
    Mar 2017
    13
    Alright thank you!
  12. #12
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    3,342
    Yes. After headers and before the CAT
    I no like autocorrect.
    JPNinPA
    Using Jeepz.com app
  13. #13
    YJ-BLAKE's Avatar
    Mar 2017
    13
    Update!!!!! Clean Spark plugs are a huge plus
  14. #14
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    3,342
    Wow. Little buildup there...you think!
    Regards,
    JPNinPA
    Sent using TapTalk
  15. #15
    YJ-BLAKE's Avatar
    Mar 2017
    13
    lol just a little bit
  16. #16
    xt master's Avatar
    Nov 2008
    NE-PA
    1,532
    Yeah that looks like it could be causing some problems.
  1. sputtering under acceleration
    By B.B.D. in forum CJ YJ TJ and JK
    Last Post: 01-07-2016, 11:11 PM
  2. 1988 cherokee engine question
    By robslob in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 04-10-2010, 08:54 PM
  3. Replies: 14
    Last Post: 07-19-2007, 03:36 PM
  4. 1988 4.0 engine blow-by
    By studabaker in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 01-28-2006, 07:12 PM
  5. 4.2 sputtering
    By Jeepster05 in forum CJ YJ TJ and JK
    Last Post: 02-01-2004, 12:57 PM
Tags for this Thread
