Thread: battery
    mandarrin's Avatar
    mandarrin is offline Senior Member
    Apr 2003
    175
    1067545
    ok.i got a new alternator.i have to jump start my jeep and it stays on,but if i turn the lights on than the battery neddle starts going down.the car stays on for a long time.i already charge the battery one time,but i didn't have a new alternator.does anyone what this could be or any adeas.please help.thanks
    89 square 4 banger 2" up
    [addsig]
    Jeeper89's Avatar
    Jeeper89 is offline Senior Member
    Oct 2002
    Harrisonburg, Va
    149
    1067550
    get a volt meter and start ur jeep and see if there is approx 14V going to the battery, if not then there is something messed up from ur alt. to ur battery, check all the wires, and then check ur alt. but if i understood right then u have a new on on there and if none of thoes work then i could tell ya :-D [addsig]
    "I have a '96 Jeep Wrangler at home in the garage, because I am doing a V8 swap"---Some Guy
    "You mean a '95 Wrangler"---Me
    "No man a '96 Wrangler"---Some Guy
    A random conversation I had with a man while i was in line buying parts at Auto Zone.
    TommyJeep's Avatar
    TommyJeep is offline Junior Member
    May 2003
    27
    1067598
    Your new alternator should be charging your battery. If you don't see 14v on the volt meter, take your battery to Pep Boys, or Sears, or somewhere they can test it. They'll do a load test to see if the battery is functioning under load. They can also hook it up to a quick charger and see if it'll accept a charge. If the battery is OK, and the alternator is brand new, I'd start checking fuses and wiring.[addsig]
    mandarrin's Avatar
    Apr 2003
    175
    1067614
    thanks guys my battery has 6 months warranty and my volt meter is only reading 8 or lower so i'm going to go ahead a change my battery for a new one because i already charge this batt one time.thanks i let you guys know what happens.
    also if anyone knows some whos selling a rear drive shaft for 2.5L 89 ax5 transmission jeep wrangler please email me at dgpena@aaaqa.com
    thanks,david[addsig]
    firemanharry's Avatar
    firemanharry is offline Senior Member
    Apr 2003
    New Jersey
    813
    1067632
    Just because an alternator is new, doesn't mean that it's good. It doesn't happen very often, but it is something to keep in mind.[addsig]
    Snitty's Avatar
    Snitty is offline Senior Member
    Nov 2002
    Olean, NY
    5,646
    1067651
    very correct... my buddy just got a new alternator... and she was no good.... that goes with any part... new doesn't mean good... but for the most part, new stuff is good[addsig]
    93 YJ 4.0
  7. #7
    jprtroy's Avatar
    jprtroy is offline Senior Member
    Jan 1970
    Scotts Valley, CA.
    238
    1068344
    Yep, alt or battery! Look at your battery connections! Is there a lot of that whitygreenish powder build-up all over the POS battery post? Make positivly sure you have a solid ground connection. If that's poor, or the POS connection is poor, no amount of new alternators will work! If the juice can't get to the battery, it'll die!
    If those are in fact ok, and your not getting the 14vdc then the regulator in the alternator is probably on vacation.
    Good luck, keep us informed as to what was up
    [addsig]
  8. #8
    carriss's Avatar
    carriss is offline Senior Member
    Jan 2003
    Mount Eden Kentucky
    319
    1068431
    This is so Cool----->[addsig]
  9. #9
    K_K_PSI_GUY's Avatar
    K_K_PSI_GUY is offline Senior Member
    Mar 2003
    Texas
    637
    1068448
    If your battery is not fully charged, then it may just need a good charge for it to work, but then again if the battery was a tad weak, your old alternator may have killed it. Thank goodness for warranties. That is why I get most of my stuff at Autozone. They may not be as good parts as the dealer, but they will prettymuch take anything back. Did you all know that they take your used brake pads back (if you bought them there), as long as they aren't worn all the way to the metal part. That's kewl.[addsig]
