Page 1 of 2 12 Last
Thread: 76 cj5 tub shot
    jams97355's Avatar
    jams97355 is offline Junior Member
    Sep 2013
    Oregon
    8
    76 cj5 tub shot
    Hi all, I'm new to the forum. I searched the forum with no solid conclusion. I am trying to find out what tubs I can use on my 76 cj5. It has a lot of rust and I want to change the tub. What other years will fit on my frame? I'd rather not alter the frame. Thanks in advance. Shane
    TLCJ5's Avatar
    TLCJ5 is offline Senior Member
    May 2010
    Homewood,Il
    671
    Re: 76 cj5 tub shot
    Any CJ5 tub will fit. The hood & fenders were shorter from 56-71. In "72 they stretched the hood & front fenders, but the tubs dimensions stayed the same.
    There's a lot of differing opinions on fiberglass vs steel for replacement tubs, I went with a steel tub from Willys-Overland(repli-tub) on my "78. 2 buddies & I had it bolted on in under an hour without rushing. I've also worked with fiberglass on other Jeeps & there are pros & cons to each. Do our homework before you spend our money.
    Lt us know what you decide & as always...Pictures are appreciated! Check out the"Jeep Builds" Forum.
    Tom Landvogt
    1978 CJ5(my toy)
    1999 TJ Wrangler Sahara(daily driver)
    2001 Cherokee Sport(wifes Jeep/winter driver)
    2002 Dodge Dakota(to tow the CJ & Wrangler)
    jams97355's Avatar
    Sep 2013
    Oregon
    8
    Re: 76 cj5 tub shot
    Thanks, that helps a lot. I'm looking for a used steel tub that is in better shape than mine. Don't want to spend too much, it's just a toy. Has the 304 with 3 speed and hard top. 33 inch tires on steel wheels. Bought it cheap. Good winter toy when I get it done. It's stuffed in my small shop so hard to get pictures yet. Also, does the title go with the frame or the body? Thanks again, Shane
    jams97355's Avatar
    Sep 2013
    Oregon
    8
    Re: 76 cj5 tub shot
    76 cj5 tub shot-20170601_115707_1496343478588.jpg76 cj5 tub shot-20170601_115724_1496343478505.jpg
    I did have a couple pictures when I bought it. Forgot about them.
    superj's Avatar
    Feb 2010
    texas
    5,754
    Re: 76 cj5 tub shot
    Nice
    78cj71ton's Avatar
    78cj71ton is offline Senior Member
    Dec 2016
    266
    Re: 76 cj5 tub shot
    Fiberglass all others are longer unless you want to stretch it into a 7 or yj
    Sent from my D6708 using Jeepz.com mobile app
  7. #7
    TLCJ5's Avatar
    May 2010
    Homewood,Il
    671
    Re: 76 cj5 tub shot
    The title goes with the majority part of the vehicle....in your case that would be the chassis. If you buy a new replacement body, they do not come with a title. If you buy a used body it may or may not have a title & or vin plate depending on the seller.
    You kind of have to make the judgment based on what you have.
    Tom Landvogt
    1978 CJ5(my toy)
  8. #8
    78cj71ton's Avatar
    Dec 2016
    266
    Re: 76 cj5 tub shot
    Not sure where your VIN# is but mine is on the dash plate. I have a 78 I replaced the old dash with aluminum but keep the old dash in safe place
  9. #9
    TLCJ5's Avatar
    May 2010
    Homewood,Il
    671
    Re: 76 cj5 tub shot
    "76 Vin plate will be on the firewall on the drivers side, just above where the wire harness comes through. It may or may not have another VIN plate on the dash.
    Tom Landvogt
    1978 CJ5(my toy)
  10. #10
    78cj71ton's Avatar
    Dec 2016
    266
    Re: 76 cj5 tub shot
    Cut the plate out. Move it to new body or just file it in the desk
  11. #11
    jams97355's Avatar
    Sep 2013
    Oregon
    8
    Re: 76 cj5 tub shot
    Thanks for all the replies. Mine is on the driver side firewall. I will save it when I get a new tub and have it if ever needed.
  12. #12
    dwillys's Avatar
    dwillys is offline Senior Member
    Nov 2015
    Reno, Nevada
    199
    Re: 76 cj5 tub shot
    Aqualu makes Aluminum bodies. BTW, good luck on doing this on the cheap and have it dependable ! lol
  13. #13
    78cj71ton's Avatar
    Dec 2016
    266
    Re: 76 cj5 tub shot
    I bought my fiberglass body used for 600 bucks. Had it for 8 years now.
  14. #14
    TLCJ5's Avatar
    May 2010
    Homewood,Il
    671
    Re: 76 cj5 tub shot
    Check E-Bay, Craigs List etc...a lot of guys start projects & then give up....good pre-owned but un-used parts are out there, sometime at great prices.
    Tom Landvogt
    1978 CJ5(my toy)
  15. #15
    78cj71ton's Avatar
    Dec 2016
    266
    Re: 76 cj5 tub shot
    That's what I did I took a while but found one. Yj tub wil fit with some mods
    Sent from my SGP561 using Jeepz.com mobile app
  16. #16
    78cj71ton's Avatar
    Dec 2016
    266
    Re: 76 cj5 tub shot
    Wait you said,cj5 scratch th yj unless you stretch it
  17. #17
    jams97355's Avatar
    Sep 2013
    Oregon
    8
    Re: 76 cj5 tub shot
    I didn't find a tub so we just started replacing the floors with some .0125 steel I had laying around. About double the original thickness of the stuff we took out. It sits level now. I have a rebuilt 304 to put in it that came with it. That's next. Then just need to replace the front fenders. PO cut the front of them off. I want the full fenders. Wire it up and test drive it. Still cheap if the motor is good.
  18. #18
    TLCJ5's Avatar
    May 2010
    Homewood,Il
    671
    Re: 76 cj5 tub shot
    Sounds like a plan....let us know how it works out.
    Tom Landvogt
    1978 CJ5(my toy)
  19. #19
    jams97355's Avatar
    Sep 2013
    Oregon
    8
    Re: 76 cj5 tub shot
    Got the floors done and the engine in. Looking for a water pump pulley for a 304.
    Local part stores don't have them and salvage yards just laugh when you say cj.
    Any suggestions where to find one????
  20. #20
    ndnatty's Avatar
    ndnatty is offline Senior Member
    Apr 2003
    Pembroke Pines, FL
    255
    Re: 76 cj5 tub shot
    I might have one, I'll check after work. I just switched out my pulley system on my 304.
Page 1 of 2 12 Last
  1. 5th gear may be shot pls help
    By jmena232 in forum CJ YJ TJ and JK
    Last Post: 05-05-2016, 06:30 AM
  2. Transmission shot
    By B'ham Jeeper in forum CJ YJ TJ and JK
    Last Post: 12-20-2007, 05:37 PM
  3. shot gun seat
    By antsinmypants in forum CJ YJ TJ and JK
    Last Post: 02-08-2005, 06:19 PM
  4. PAP Shot!!! July 24?
    By dick_wilderness in forum Events
    Last Post: 07-20-2004, 01:21 AM
  5. 97 tj with a shot 5 speed
    By Bounty__Hunter in forum CJ YJ TJ and JK
