    otis60's Avatar
    otis60 is offline Junior Member
    Aug 2017
    4
    High Idle 3000 to 4500 rpms
    I have a 99 TJ. The engine was running fine until I replaced the exhaust manifold. Now when I start in it is idling at 3000 to 4500 rpms. The throttle is not stuck open it works fine. I had to disconnect the fuel line to the fuel rail I did not remove the injectors from the intake. All vac hoses are fine no cracks or leaks . need help what is causing this to happen?
    k-2's Avatar
    k-2
    k-2 is offline Senior Member
    Apr 2017
    213
    Re: High Idle 3000 to 4500 rpms
    knee jerk answer- there is a vacuum leak.
    PCV/CCV, brake booster va lnes?
    try the old school carb spray trick to locate vac leak - intak manifold?
    tell us which eng. 2.5 4.0 ? Why new manifold?
    THe system would have a code SO a scan would be a start - even if light is off post codes
    otis60's Avatar
    Aug 2017
    4
    IT is 4.0. I scanned it no codes at all. I replaced the exhaust manifold because the flange to the header pipe rusted off.
    k-2's Avatar
    k-2
    Apr 2017
    213
    did you use a scanner? That rpm I would expect code .
    Use the old school spray trick for a vac leak, you did replace manifold gaskets ?
    otis60's Avatar
    Aug 2017
    4
    yes new gasket.
    superj's Avatar
    Feb 2010
    texas
    5,719
    you have a vacuum leak somewhere
  7. #7
    otis60's Avatar
    Aug 2017
    4
    Found the leak the #2 intake flange on intake manifold.
  8. #8
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    3,653
    Glad you found it.
    When you replaced the exhaust you had to loosen the intake. There are two locater pins on block to marry with the intake. So if you loosened it enough the intake may have slid on top of the locator pins. Just be sure you look to make sure the intake is not on the pins but the pins are in the holes. If you just torque down on the bolts you run the risk of bending the intake and more leaking will follow.
    Also are you aware there is an order to tightening the intake and exhaust bolts. And these bolts stretch so you only get a few tightenings out of them and too many ft-lbs of torque will stretch them.
    Regards,
    JPNinPA
    Sent using TapTalk
  1. Auto-trans stuck in low- high rpms... Diagnosing symptoms within
    By curtisbk in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 03-11-2014, 06:54 AM
  2. High Idle??
    By captjanes in forum CJ YJ TJ and JK
    Last Post: 06-04-2011, 04:22 PM
  3. Idle too high.
    By uncleair in forum CJ YJ TJ and JK
    Last Post: 10-09-2007, 02:08 PM
  4. help with idle speed actuator ISA - idle way too high upon i
    By bucklahoo in forum CJ YJ TJ and JK
  5. fast idle & tops at 3500 rpms ???
    By jay89 in forum CJ YJ TJ and JK
