    hoytman62's Avatar
    hoytman62 is offline Member
    Dec 2012
    37
    2006 Wrangler X TJ Automatic Transmission Shift
    When my transmission is cold the second gear shifts hard. Once it warms up, it doesn’t do it. I had the computer reloaded and it will quit for a day or so then start again. The Transmission has been rebuilt by a very reputable company that does only transmissions. Any ideas?
    Thanks!
    Sent from my iPad using Tapatalk
    Hoytman62
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    3,720
    Re: 2006 Wrangler X TJ Automatic Transmission Shift
    Be sure the correct trans oil is in there. I only had that issue when it got below zero deg F.
    JPNinPA
    Using Jeepz.com app
    k-2's Avatar
    k-2
    k-2 is offline Senior Member
    Apr 2017
    288
    try scanning for codes- must use a scanner.
    Don't know till you look
    Any chance remote starter - or modified wring?
    somethng dumping saved data -adaptives
  1. 99 wrangler automatic transmission issues
    By Clip4x4 in forum CJ YJ TJ and JK
    Last Post: 05-05-2015, 05:36 PM
  2. Wrangler automatic transmission won't shift into gear
    By TerryMason in forum CJ YJ TJ and JK
    Last Post: 04-25-2014, 10:07 AM
  3. 2006 Wrangler 4.0 will not shift into gear
    By big d in forum CJ YJ TJ and JK
    Last Post: 12-12-2012, 11:26 PM
  4. 2003 Wrangler TJ automatic won't shift into gear
    By Adrian1868 in forum CJ YJ TJ and JK
    Last Post: 04-02-2010, 03:21 PM
  5. Transmission BIG TIME trouble...99 Wrangler Automatic, 4.0 H
