Thread: Lift kit
    syrekn_390's Avatar
    syrekn_390 is offline Junior Member
    Nov 2017
    8
    Lift kit
    So I Recently put 31 ko2s and 2 spacers all around on my 2000 TJ and Im going to be looking into lifting the jeep this spring. I dont know what sites to look at for a good lift. Is buying rough country lift kits ok? Obviously im doing a suspension lift and Im looking to go around 2-3.5 lift. If anyone has knowledge on good quality lift kit sites Id be happy to hear from ya. Any advise helps. #jeepon
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    3,784
    Re: Lift kit
    Rough county is ok. You need more than what comes in some of the kits so don't look st price only.
    Up to 3 inches you will need: Bump stops, extended brake lines, adjustable track bar front and back. Possibly shims for the skid plate or extended motor mounts if you get vibrations in the driveshaft. If you go above3.5 in you will likely need the above plus slip yolk eliminator
    Obviously springs and shocks. Though a 2in BB you could get away with just the BB. You might want the adjustable track bar.
    JPNinPA
    Using Jeepz.com app
    Bounty__Hunter's Avatar
    Nov 2002
    Southern Illinois
    13,358
    Re: Lift kit
    Is your current lift coil spacers or body mount spacers?
    Jeepergeo's Avatar
    Jeepergeo is offline Senior Member
    Dec 2010
    California
    333
    Re: Lift kit
    The Ribicon kits are well built. I like the long arm, but for the minor lift you are contemplating, a short arm lift should be fine. At 3", beware you should be considering a short shaft mod for your transfer case as the drop kits can lead to shifting problems.
    syrekn_390's Avatar
    Nov 2017
    8
    Re: Lift kit
    Quote Originally Posted by Bounty__Hunter View Post
    1 body leveling kit
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    3,784
    Lift kit
    Quote Originally Posted by syrekn_390 View Post
    1 body leveling kit
    So to me that is a coil spacer lift. It goes between the coil and coil bucket.
    Or is yours pick like spacers that go between the body and frame?
    JPNinPA
    Using Jeepz.com app
  7. #7
    syrekn_390's Avatar
    Nov 2017
    8
    Re: Lift kit
    JPNinPA
    Using Jeepz.com app
    The a body lift so between the frame and body.
  8. #8
    Nov 2002
    Southern Illinois
    13,358
    Re: Lift kit
    Rough Country kits are okay for road use and light offroad. They're just not built heavy enough for hard offroad use.
  1. Alternate Drive shafts for CJ with lift(2.5 lift)????????
    By jhiggins in forum CJ YJ TJ and JK
    Last Post: 12-03-2011, 04:19 AM
  2. 4" lift... rancho lift springs
    By frhrwa in forum Items for Sale, Trade, or Give Away
    Last Post: 04-04-2011, 10:39 AM
  3. Motor Mount Lift + Body Lift = can't shift into 4wd Low
    By TerryMason in forum CJ YJ TJ and JK
    Last Post: 03-16-2011, 04:36 PM
  4. Should I install a motor mount lift to go with my body lift?
    Last Post: 03-14-2011, 06:52 PM
  5. coil spacer lift vs. body lift?
    By PASmokeater in forum CJ YJ TJ and JK
