Page 2 of 3 First 123 Last
  1. #21
    TerryMason's Avatar
    TerryMason is offline Administrator
    Dec 1999
    Virginia Beach VA
    7,776
    Re: Turbogus' long slow Team Rush upgrade
    That's rough. Glad you're on the mend though.
  2. #22
    Turbogus's Avatar
    Turbogus is offline Senior Member
    Nov 2005
    Albany~town, Oregon
    1,321
    Thanks Terry :)
    Quick fixes are so named for how long they stay fixed.
    If you run out of gas, no matter which way you decide to push, the closest gas station will always be uphill and in the other direction. Corollary: The likelihood of running out increases when all of the nearby gas stations are closed.
    The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep.
    We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch).
  3. #23
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,321
    I got the MSD wires yesterday and I brought the Accel No.1 wire with me to work. I'm used to the Accel crimper and this one from MSD is a little different. Going to figure it out today and then get on to the rest of the wiring.
  4. #24
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,321
    So opening the kit I found two styles of crimp terminals;
    These terminals are described as the bronze colored Standard, and the silver colored Dual Crimp
    I'm using the MSD Cap-a-Dapt and I believe the 90* Dual Crimp is what I shound be using, or could I be wrong?
  5. #25
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,321
    I finally got through to the MSD Tech line and it is the silver double crimp for the Cap-a-dapt caps.
    Turbogus' long slow Team Rush upgrade-5473414_l_b682e984-12b9-4b80-bf32-325f403b4222.jpg
    One thing not mentioned in the instructions was the wire labels ~ Note: It's much easier to slip these on before crimping the terminals on.
  6. #26
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,321
    ...another tip: When stripping the wire using the sizing crimping block included in the Universal Set use extra caution NOT to cut the Helically wound copper alloy conductor #8
    I found out the hard way and ruined two wires.
  7. #27
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,274
    Oh dang it!
    Thanks!
    JPNinPA
    Using Jeepz.com app
  8. #28
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,321
    Yep, I was better served by using the method I used on those old school Accel wires, with a steady hand and a razor blade.
  9. #29
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,321
    This is Important
    When stripping the wire to expose the conductive strands it is nesessary when pulling the outer shielding from the wire to be pushing the core oppositely. The reason for this is the core strands are so tightly enclosed by the inner sleeve it can become unraveled leaving you to cut and start again!
    I used a ball point pen to poke through and it worked well.
  10. #30
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,321
    On the first wire I tried for cylinder #1 it got roached to the point that it was too short. The good folks at MSD though siad they'd send me a new wire cut to length and all set up. These guys are on my 'great' list.
  11. #31
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,321
    I just bought a Standard Blue Streak FD 478 coil and hopefully 'Black Betty' will be on the road again soon. :)
  12. #32
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,274
    You might share your learnings with XJ Reaper. He has been struggling.
    JPNinPA
    Using Jeepz.com app
  13. #33
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,321
    Hmmm I ran a search for XJ Reaper in the Username but came up zilch. Are they in another forum?
  14. #34
    TerryMason's Avatar
    Dec 1999
    Virginia Beach VA
    7,776
    Now Turbogus you know there aren't any other Jeep forums!
    I think JPNinPA is referring to this:
    https://www.jeepz.com/forum/cherokee...-cherokee.html (94 cherokee)
  15. #35
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,321
    Thanks Terry, I fired off a PM to him. Have a great weekend!
  16. #36
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,321
    Well, I had a custom mounting from the P.O. for the canister coil and I was able to modify it to fit the e coil prettry easily with a cut off wheel and my bench grinder.
    I then just drilled two matching holes for the smaller bosses on the coil and it's very snug.
  17. #37
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,321
    It was a tight fit, on account of the forward vacuum hose but it's tight and installed now. Since I moved the distributor when I added that alignment tab I'll re-time the motor to spec.
    I've got to get some dielectic grease on the rotor tip and tab before I forget.
  18. #38
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,274
    Thats looking great!
    You should be quite proud!
    JPNinPA
    Using Jeepz.com app
  19. #39
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,321
    I would be JPN, but upon startup I could tell that the motor was loading up the plugs. I turned the distributor to get at that alignment tab but did not remove it. I had returned the distributor was very near where it was before this work, I was intending to check the timing but dinner was getting cold. Going to try to recheck the wiring tonight as I may have pulled something loose when I turned the distributor. Before checking the timing I've got to get under there and clean up my timing marks. Since getting these damnable bifocals it's hard to focus down there. I'm need'n a rifle or spotting scope I guess.
  20. #40
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,321
    I just ran across a photo of the stock location of the spark plug wires, I wish I'd have seen that before I began this adventure. Mine are kind of messy, but I'd been advised to seperate each wire as far as i could. I guess these old AMC motors are right finiky, the Chevy 350's I'd run in the past 35 years were not so.
    There was a bunch of white paint on the dampner pulley making it near impossible to zoom in on the timing mark. So I rotated the crank by hand and wire brushed to paint off until I could find the mark. I then used a paint pen to enhance visibilty, I still have yet to mark the timing marks, was hoping after cleaning up a marker would suffice to enhance the lettering.
    I pulled the spark plugs on the left bank and sure enough, they were fuel fouled. I could clean them up with my HF mini sandblaster spark plug cleaner, but if it's not premature I'm thinking I'm going to go with Autolite 646's for the larger gap. I have yet to purchase and install the MSD 6 yet, I want to sort out the tune of the motor first.
  1. team rush
    By FredDog01 in forum CJ YJ TJ and JK
    Last Post: 02-09-2016, 01:57 AM
  2. Replies: 8
    Last Post: 09-28-2012, 01:45 PM
  3. Replies: 7
    Last Post: 08-21-2012, 02:28 PM
  4. team rush Quality parts?
    By 5pd in forum CJ YJ TJ and JK
    Last Post: 09-30-2009, 10:23 PM
  5. Long-arm upgrade for Skyjacker 4" lift
    By socal_rob in forum CJ YJ TJ and JK
    Last Post: 05-12-2006, 12:05 PM
