Carter AFB will not idle down
Turbogus
Now that I've got the ignition figured out time to tune that "Black Stallion" Carter AFB (like an Edelbrock Performer) I've had since the mid '80's.
A couple of years back it developed a small leak at the primary throttle shaft. I sent it in for bushing installation and following that I did a bebuild with a Jiffy kit.
I lost the choke pivot pin (nomenclature unknown) that connects the piston to the lever inside the electric choke. I found that a smooth paper clip, cut down to length fit nicely in the tiny bore.
Time has gone by and after doing other work on the motor this AFB is on despite several attempts I can't seem to diengage the fast idle cam, unless I manually disengage it by reaching under the air cleaner and doing so. It may be related to the repair I mentioned above but I'm dubious.
There's no binding in the linkage that I can determine.
21202d1446497347-carter-afb-throttle-body-repairs-formerly-timing-180-out-p1060441.jpg
Has anyone else had this issue?
My inner mechanic had a word with me this morning before I got up, I'll bet I didn't put enough spring tension on the clockspring of the electric choke.
I may get into that today during my break.
After getting into it more closely I finally found that the throttle return springs were rubbing on the cam of the kickdown slowing/prohibiting it's motion. Going to try to find offset throttle return springs.
Here's the difference;
No wonder those springs were hanging up the fast idle cam tang :roll:
...but do you think I could find these locally.... NO
Yah unless you have an actual spring mfg and know all the dimensions and spring rate... What looks the same will likely not work.
There is a o-ring shop here that can match material, size.... Nice to have around.
Regards,
JPNinPA
Sent using TapTalk
This was just a generic throttle return spring that I recognized was on a 427 Chevy motor that was a project many years ago. The Ebayer's ad said it crossed to Chevy Ford and Mopar. I see to recall these offset return springs were once common, but not around here anymore. Corvallis has turned from a mech friendly town to a college fast food and upscale eatery town. The Mom and Pop places (including auto parts) are long gone.
Counter intuatively I rotated the e choke in the opposite direction and after taking it for a spin it idles down just fine at long last :)
