TJ Mirror temperature sensor location
southtj
Active member
My mirror displays the direction and temperature but the temperature is about 20 degrees too high. Anyone know where or how I can locate the sensor and maybe relocate it? I'm thinking it's too close to the hot bits somewhere.
I know it should be located between the radiator and grill but I don't see it.
Does it stay too high or does it correct itself after you get down the road a ways?
The xj I used to have would read real high if it set in the sun but a mile or so down the road it would be correct. For whatever reason my black jk only shows a little high and corrects itself sooner. I don't know where they hide the sensor.
Yeah, past Jeeps I've had did that as well. When you first start it up, it shows high until you drive it a while. Mine is always about 20 high no matter how long I've driven it.
If it was on Celsius, it would be reading 25-30 degrees instead of over 100.
