Thread: p0523
    draco212sti's Avatar
    draco212sti is offline Junior Member
    Mar 2019
    3
    p0523
    So my 2012 jk 3.6l is throwing P0523 code and I have changed out the oil pressure Sensor with a OEM part. Tried to clear the code and it is still throwing the code. Now what? Would a bad CCV valve have anything to do with it?
    mark sr's Avatar
    mark sr is offline Senior Member
    Apr 2010
    east tenn
    240
    Re: p0523
    It could be a fault in the wiring to the sensor.
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,480
    Re: p0523
    Is your battery in good condition?
    Do you have good clean ground connections?
    Bad battery or connections cause faulty codes.
    What weight oil do you use?
    Change it regularly?
    Bad sensor or wiring?
    Did you use OEM sensor
    Mar 2019
    3
    Re: p0523
    -Yes I used OEM
    -Iíll check the battery
    -Iím sure itís not the sensor as I have placed 2 different ones in there just to makes sure that it was not a bad one.
    -Oil is fine I change it every 3k.
    So Iím leaning towards wiring. Just wanted to know if there was anything else I might be missing.
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,480
    p0523
    So what weight oil do you use?
    Mar 2019
    3
    Re: p0523
    5 30 synthetic
  7. #7
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,480
    Re: p0523
    Yah Id look at the wiring or checking the pathway to the sending unit for buildup or sludge.
