    buttons276's Avatar
    buttons276 is offline Member
    Jun 2019
    Yadkinville, NC
    34
    Ugh...a month in and another issue...
    Just venting...Iíve had this Jeep a month. The first day it had to go back because the axle seals were leaking. Now my radiator is leaking. Can things stop breaking please
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,897
    Where is it leaking?
    I had a good stretch with no issues. Then one day all hell broke loose. Not so bad on the Jeep but my Honda needed everything.
    buttons276's Avatar
    Jun 2019
    Yadkinville, NC
    34
    Re: Ugh...a month in and another issue...
    Along the edge where the plastic attaches to the aluminum. Just one of those things. It shouldnít cost to much to replace. I think we can get them through work for about 75 dollars. Just frustrating
    buttons276's Avatar
    Jun 2019
    Yadkinville, NC
    34
    Atleast it looks really easy to change.
    buttons276's Avatar
    Jun 2019
    Yadkinville, NC
    34
    Itís kinda funny I have a grand Cherokee that Iíve had for years and it has the same two problems Iíve had on the wrangler. Axle seal leaking and a water leak. The water leak is a lot slower in the grand Cherokee though
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,897
    Ok had to replace mine cause it blew-up! I did a lot of reading and searching. If you plan to wheel or live anywhere hot or high altitude, you want OEM or as close to OEM. The alternative is overheating. The OEM radiator has more cell density than others. Because of this it is very efficient exchanging heat.
    Changing it is not bad. Keep the spring clamps and replace with spring clamps. The spring clamps move with heating and cooling where the SS band clamps will not move and will cut into the hose.
    I learned the radiator caps only last 2 years or so. When they fail to open the result is the next weakest thing fails.
    Regards,
    JPNinPA
    Sent using TapTalk
  7. #7
    buttons276's Avatar
    Jun 2019
    Yadkinville, NC
    34
    Things must be a lot worse where you live. We always replace spring clamps with just regular clamps. We have a local place we get all our radiators from. I guess they are decent. We have never had any issues. Much cheaper than mopar thats for sure.
  8. #8
    TerryMason's Avatar
    TerryMason is offline Administrator
    Dec 1999
    Virginia Beach VA
    7,933
    I did my radiator last summer - I was amazed at how cheap they are - about $100
    https://www.amazon.com/Spectra-Premi.../dp/B000C7TUMU
    The swap wasn't that hard - it just takes some time. Keep in mind that if you have an automatic transmission, your radiator likely has the transmission cooler build in, so you'll need to replace some transmission fluid as well. This makes for a great time to change transmission fluid.
    My 2005 Wrangler Build Thread
    ďHe who is without oil shall throw the first rod.Ē -Compressions 8.7:1
  9. #9
    buttons276's Avatar
    Jun 2019
    Yadkinville, NC
    34
    Yeah I changed it yesterday. My boss let me do it at work. Very easy
  10. #10
    buttons276's Avatar
    Jun 2019
    Yadkinville, NC
    34
    Lol I swear to god this Jeep is going to dollar me to death and itís only been a month. I got to work today and leaned down to get something from the floorboard and noticed my transfer lever was loose. Flopping basically. I was a little early so I pulled it on the lift...looks like the bushing on the inside came apart. Ordered one. 10 dollars and more aggravation. I love this damn Jeep but man I wish I could get all of the bugs worked out of it.
  11. #11
    buttons276's Avatar
    Jun 2019
    Yadkinville, NC
    34
    Crazy thing is the first day I test drove it I put it in 4 hi and 4low to test it and it was working fine then. I guess it broke when I put it back into 2wheel drive. I have the worst luck. Have any of you guys tried that purple b&m short shifter? Iím seriously considering it. 500 bucks is a lot but it seems to solve a lot of headaches for people.
  12. #12
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,897
    I just watched a video of a guy swapping one in to get rid of the shaking shifter. Looked easy. It was tight.
    https://youtu.be/kuKhtQ0sdy8
    Regards,
    JPNinPA
    Sent using TapTalk
  13. #13
    vinn's Avatar
    vinn is offline Member
    Dec 2015
    94
    my 94 yj 4 cyl. dip stick broke off and fell into the oil pan. i now use a speedometer cable to check the oil level.
  14. #14
    TerryMason's Avatar
    Dec 1999
    Virginia Beach VA
    7,933
    Quote Originally Posted by buttons276 View Post
    Any chance that Jeep has a body lift? I've got a body lift on my TJ, and it makes getting the shifter angles lined up a bit challenging.
  1. TJ of the Month Contest!
    By Poobah in forum General Chat
    Last Post: 08-28-2009, 07:14 PM
  2. TJ of the Month Contest!
    By Poobah in forum CJ YJ TJ and JK
    Last Post: 08-27-2009, 10:38 AM
  3. anyone read JP this month
    By lethaldose in forum General Chat
    Last Post: 10-24-2006, 01:17 PM
  4. interesting rig of the month
    By mingez in forum General Chat
    Last Post: 02-24-2005, 05:27 PM
  5. Jeepz.com rig of the month
    By Sully in forum General Chat
    Last Post: 03-20-2004, 11:45 AM
