    HexedHero's Avatar
    HexedHero is offline Junior Member
    Aug 2018
    15
    In need of front end repair and replacement
    This weekend we took a huge dive into my busted up front end and tore everything apart. Bushings, o rings, bearings, seals etc. there is nothing in the front end anymore and we went to the jeep dealership and they told us that the parts we need to seal and fix the front end are discontinued. If anyone knows anything about these parts for a front end on a 95 wrangler, rio grande. Please let me know where I can get them, I can’t live without my 4wd.
    TerryMason's Avatar
    TerryMason is offline Administrator
    Dec 1999
    Virginia Beach VA
    7,972
    Re: In need of front end repair and replacement
    I wouldn't bother doing all that. I'd just get a new front axle. I don't know where you live, but here's a set of front and rear YJ axles for $400, in North Carolina
    https://eastnc.craigslist.org/ptd/d/...925926204.html
    The only thing you'll need to do is make sure you match the gear ratio that's in your rear axle to the front axle. You want the gears to be the same in front and back, so that the tires spin at the same speed.
    Replacing the whole axle is much easier than doing all the work you'r talking about. Just put the tires on it, roll it into place, then connect the springs, driveshaft, etc.
    My 2005 Wrangler Build Thread
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    5,038
    I actually have a lot of luck googling the part number and name or description.
    Quadratec has a section for OEM replacements. Might find it there.
    Regards,
    JPNinPA
    Sent using TapTalk
  1. Front Bumper replacement
    By B192734 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 06-04-2013, 02:38 PM
  2. Front End Repair Help
    By musikfreak477 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 01-30-2011, 11:44 AM
  3. Repair or replace front seat restraints?
    By glassmaster in forum CJ YJ TJ and JK
    Last Post: 08-22-2010, 11:41 AM
  4. Front axle repair
    By Utah_jeepster in forum CJ YJ TJ and JK
    Last Post: 01-12-2004, 09:50 PM
  5. Chassis repair or replacement questions?
    By hi_c in forum CJ YJ TJ and JK
