    NCK's Avatar
    NCK
    NCK is offline Junior Member
    Aug 2019
    6
    Need upgrade advice
    Iíve got a Ď95 wrangler and want to lift it slightly and put bigger tires on. Itís totally stock, and Iím wanting to keep a factory ride. I wonít be crawling over any rocks or mud bogging with it but it is used as a hunting rig and used around the farm checking fence and cattle. Iím guessing a 2Ē lift and 31Ē tires is what would work for me but ultimately I have no idea. Thereís no 4x4 clubs or ďlift shopsĒ here and not really many Jeep wranglers around for me to compare to, which leads me here! Iíve read a lot of back and forth on suspension lift vs body lifts and havenít really come up with a one is better than the other. So some insight would be much appreciated!
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    5,032
    Re: Need upgrade advice
    How much do you want to spend?
    How much do you want to lift?
    NCK's Avatar
    NCK
    Aug 2019
    6
    I would like to stay under $500 for the lift and I am thinking a 2” but not really for sure.
    NCK's Avatar
    NCK
    Aug 2019
    6
    Stock tires are 235/75R15, Iím going for little taller stance and beefier look so just not sure if 31Ē tires with 16Ē rims along with 2Ē lift will raise it too much or just right. Was just wondering if anyone of you folks out there upgraded in a similar fashion.
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    5,032
    Need upgrade advice
    Two inches to 2.5 in it is then. Any more then that, like >3" and there is more you will be changing. Plus $$ Definitely at 4" and up becomes $$$.
    With 2.5 in you can fit 32 maybe 33 in tires. See link below.
    You will need wheels with 3.75 back spacing or spacers that get you to 3.75 equivalent. Without it the tires will rub when you turn. I don't know if any still make 32x9.5 or 33x9.5 anymore but the skinner tires will not rub. Maybe SS bias tires.
    And taller tires will put your speedometer off. If you care there are speedo gears you could change to correct for bigger tires.
    https://www.quadratec.com/jeep_knowl...article-10.htm
    Regards,
    JPNinPA
    Sent using TapTalk
    mark sr's Avatar
    mark sr is offline Senior Member
    Apr 2010
    east tenn
    273
    For cable driven speedos they sell a little gizmo that goes between the end of the cable and where it attaches to the outside of the transmission. You need to know how much it's off before you order one.
  7. #7
    NCK's Avatar
    NCK
    Aug 2019
    6
    Thanks for the info guys much appreciated and the link to the Quadratec page was exactly what I was looking for. Last question do you suppose I would need wheel spacers for 31s? After looking at the link and tire rack.com tire chart I think that’s what I’ll go with.
  8. #8
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    5,032
    Need upgrade advice
    According to rough country backspacing is needed. However i ran 33x9.5 without rubbing. 33x10.5 rub at full turn with 5in backspacing. So 31x10.5 may be fine. Could do it in phases. The rubbing would be on the springs or control arms in my place
    Spacers will work if you like the wheels you have. Steel rims are as much as or close to the cost of spacers
  9. #9
    TerryMason's Avatar
    TerryMason is offline Administrator
    Dec 1999
    Virginia Beach VA
    7,972
    Just to throw my two cents in. When I had my CJ (it also had a leaf spring suspension), I was worried that it would ride hard after lifting it. It turns out that when I replace the worn out factory suspension with new leaf springs it rode much better.
    My 2005 Wrangler Build Thread
    ďHe who is without oil shall throw the first rod.Ē -Compressions 8.7:1
  10. #10
    NCK's Avatar
    NCK
    Aug 2019
    6
    Yeah I guess that was my next question- do you guys prefer body lifts or suspension lifts? i am a mechanic by trade and neither one seem real difficult to install but figuring out which is the best application is the challenge. I’ve read that body lifts will cause a gap between the cab and bumpers that may be unattractive.
  11. #11
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    5,032
    Need upgrade advice
    Personally Id go suspension then body. As mentioned id not go more than 1 in body lift. Too much stress on the bolts. Ive seen and heard of bodies slipping and falling off with 2+ greater of body lift. Plus it will cause issues with shifting the transfer case and there are fixe$$.
    1 in body lift is barley noticeable. If , like me, you have a manual trans the body lift causes issues with shifting. You will need to either mod the fan shroud or add a 1 in motor lift. There are good youtube vid on the process.
    I just replaced a 10+ yr old lift and notice an improved ride. And i fo mot have s body lift.
    You could cut the tub and fenders to stuff bigger under and keep low center of gravity COG. Or hi line the front. Though you likely fit 33x10.5 on 3.75 ď backspacing easily. That is as long as you donít disconnect sway bars and go high articulation.
  12. #12
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    5,032
    Tj 1.25 body lift 1/2 complete
  13. #13
    NCK's Avatar
    NCK
    Aug 2019
    6
    Hey guys newbie here again! Been doing research and I’ve got some more questions. I’m kind of set on 2.5” RC lift with some 32” sitting under me and been reading a lot about regearing the axles and dropping the transfer case. Wanted to know thoughts on it if it’s even necessary to do for no more than I’m planning on doing to it.
  14. #14
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    5,032
    Need upgrade advice
    What engine, 4cyl or 6 cyl?
    What rear gears do you have?
    On the TJ A 2.5 in lift didn't need transmission case drop. But a YJ may get more lift with leaf springs. I'd put the lift on then decide.
    So by decide I mean look at the shaft angle and rotate the shat looking for binding. Listen for vibration when driving.
    Unless someone could give direct experience.
    Also in place of a trans drop you could do a 1in engine lift.
    Regards,
    JPNinPA
    Sent using TapTalk
  1. Infinity upgrade advice...pleeeease
    By Philzzz in forum CJ YJ TJ and JK
    Last Post: 05-13-2017, 12:43 AM
  2. Want to upgrade
    By supastar2353 in forum New Member Introductions
    Last Post: 05-17-2009, 04:12 PM
  3. '90 4.0 to an HO upgrade?
    By jaber in forum CJ YJ TJ and JK
    Last Post: 11-09-2008, 07:31 PM
  4. To upgrade or not to upgrade
    By dracowing14 in forum CJ YJ TJ and JK
    Last Post: 08-05-2008, 09:45 PM
  5. TJ upgrade advice
    By Jason4x4 in forum CJ YJ TJ and JK
    Last Post: 11-13-2006, 04:41 AM
