07 Wrangler Unlimited Build Advice
COcrawler
I just got a 07, 4 door wrangler it is essentially stock. I don't have the money for a high quality suspension upgrade at the moment, I'm putting it off until I can do it right. What upgrades would you guys recommend making ASAP. I've heard the stock bumpers are almost useless, should I start there? It already has bigger mud tires, a light bar, new Fender flares, and LED headlights. Keep in mind I'm using it as a daily driver too.
I am curious what suspension people recommend. I'm trying to have good clearance while still keeping the center of gravity low. I'm thinking no more than a 3.5" or 4" suspension lift would fit my needs.
Lastly I'd love to get some Dana 44s on it but again I'm thinking that's something for later down the road.
What do you plan to do with the vehicle? Light off road, daily driver only, moderate off-road, mud, rock crawling?
FYI - Low COG (center of gravity) uses high line fenders, cut out rears have larger tires and 2.5 or lower lift.
Regards,
JPNinPA
Sent using TapTalk
