    smalls42010's Avatar
    smalls42010 is offline Junior Member
    Nov 2019
    6
    05 Jeep loses power in 3rd
    Ok so i just started having this problem this morning.
    When ever I shift into 3rd or 4th gear I lose all power to my jeep it only does it after ive been driving for about 15 20 mins.
    its a 05 wrangler 4.0 6speed stick.
    all ideas would be appreciated, Thanks
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,897
    Re: 05 Jeep loses power in 3rd
    Is the CEL check engine light on? What codes show?
    When this is occurring does the rpm go up but you donít go faster?
    Slipping clutch??
    Check clutch fluid. Possible failing slave cylinder.
    Worn out clutch.
    After a few min the engine warms and goes into closed loop. This is when it uses info from O2, temp, map and cpk and cps sensors.
    Is your idle fast or slow? What rom do you idle at?
    Nov 2019
    6
    no check engine light is on.
    slave cylinder is fine
    when it does it its just dies but after a second or 2 it comes back to life
    but it doesn't do it all the time that's what gets me.
    idles fine
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,897
    Certain pedal position? TPS may have dead spots.
    Nov 2019
    6
    Maybe, ill check into that. it has a brand new tps on it
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,897
    Have you pulled and inspected your plugs?
    They can show signs of oil burning, lean or rich conditions...
  7. #7
    Nov 2019
    6
    No i have not, ill check into it in the am
  8. #8
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,897
    Post pics of each plug
    Regards,
    JPNinPA
    Sent using TapTalk
  9. #9
    Nov 2019
    6
    Regards,
    JPNinPA
    Sent using TapTalk
    Sorry for the late response, all plugs were fine.
  10. #10
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,897
    Figure it out?
    Regards,
    JPNinPA
    Sent using TapTalk
  11. #11
    Nov 2019
    6
    Figure it out?
    Regards,
    JPNinPA
    Sent using TapTalk
    Yes I did, it was my crank position sensor.
    Thanks for your help!
  1. Jeep yj loses power while driving
    By CplRecon in forum CJ YJ TJ and JK
    Last Post: 11-25-2017, 12:36 PM
  2. Ticks at high RPM's loses power when ticking starts, what could be the problem? VIDEO
    By Dragon-Kin in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 04-08-2014, 02:56 PM
  3. Cj-5 loses all power when i turn the key
    By bexican73 in forum CJ YJ TJ and JK
    Last Post: 02-25-2012, 10:52 AM
  4. 85 Grand Wagoneer loses power while driving
    By Florence725 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 08-10-2011, 09:55 AM
  5. 1998 Cherokee 2.5 td loses power/acceleration
    By pants in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 05-19-2005, 09:08 AM
