    JasonW's Avatar
    JasonW is offline Junior Member
    Nov 2019
    2
    2007 Wrangler 6-speed Manual Won't Go Into Gear
    Hi All,
    I'm new here. I'm hoping to get some ideas or answers on why my Jeep won't go into gear. I bought the car used about 2 months ago. It has a 6-speed manual transmission and up till November 8th, its been great. Now, the shift won't go into any gear. Please help!
    Thank You,
    Jason
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,950
    When you push the clutch does it feel like something is moving? More than the spring. Could be the slave cylinder failed. Could be the throughout bearing
    Or something failed or came off pivot points.
    JasonW's Avatar
    Nov 2019
    2
    Re: 2007 Wrangler 6-speed Manual Won't Go Into Gear
    Hi,
    It does feel like something is moving. When I try to put the shifter in gear, you can hear the engine rpm's drop a little.
    Jason
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,950
    Does it go into gear engine off? If not it may be internal synchros.
    The NSG370 has issues with 2nd gear and reverse.
    Forgotbto ask do you have a body lift?
  1. Replies: 0
    Last Post: 02-14-2013, 01:07 PM
  2. JK Manual Gear Frustration
    By gcaron3 in forum CJ YJ TJ and JK
    Last Post: 04-08-2009, 04:57 AM
  3. 3 speed manual transmission noise
    By dave123 in forum CJ YJ TJ and JK
    Last Post: 09-05-2007, 09:51 PM
  4. Ford T18 4 speed transmission with granny first gear!!!
    By harletaz in forum Items for Sale, Trade, or Give Away
  5. HELP! Peugeot BA10 5-speed manual transmission
    By RayOvac in forum Cherokee, Commander, Wagoneer and Liberty
